200R tranny?
Discussion in 'The Hokey Ass Message Board' started by Jalopyrama Mike, May 27, 2011.
  1. Ralphies54
    Ralphies54
    Great transmission, got a 200-4R in my 57 chevy and a700-R4 in my 54 pickup. Love them both. Proper adjustment of the TV cable is a must or they will burn up very soon. Another plus for the 200 is they fit in place of a power glide or a 350 in a Tri 5 chevy as they are the same lenght and the smaller diameter make for more exhaust room.
  2. Jalopyrama Mike
    Jalopyrama Mike
    Bellytanker, I was told this 200 metric is in a '88 Monte Carlo. Could that be? The 200 Metric is a 3 speed as opposed to the 200R4 which is a 4 sp OD.
  3. 71buickfreak
    71buickfreak
    from Oklahoma
    The last year for the TH200 was 1987, and it was used mostly in X body cars (Nova, etc). The Monte is a G-body, and those all got 2004Rs if it had overdrive, otherwise they got the TH350. If it has a (d) or a [d] on the shift indicator, its a 2004R.
  4. Bellytanker
    Bellytanker
    +1 with Buickfreak, If you can look at the car, the shift indicator should be a good indicator (no pun intended). I don't think that the smaller 200, ( a 3 speed) would have been in the Monte Carlo, at least through '85 the Monte came with the 200-4r. I happened to be under my Model A the other day and realized that it says "Metric" on the pan. I had forgotten that bit of info. But as stated earlier, if you can see the trans it would be easy to identify by the pan shape. K.
  5. Jalopyrama Mike
    Jalopyrama Mike
    Thanks Bellytanker, I hope that is why the guy said it was "metric". I'll go take a look later this week. Got the shape of the 200-4r engrained. J'mike
  6. Jalopyrama Mike
    Jalopyrama Mike
    Was told the shift indicator has 1-2-(d)-D; so I'm ***uming it's a 4 speed OD 200-4r.
  7. I believe that the 88 200-4R is computer controlled...you can still use it. The Monte Carlo 200-4R is second only to the Buick Grand National 4R...
