Technical 200R4 shifting question
Discussion in 'The Hokey Ass Message Board' started by willys36, Oct 24, 2024.
  1. willys36
    willys36
    I have a new BowTie Overdrive 200R4 with their throttle cable cam that p***ed all the pre-pressure tests. I test drove it and it shifts at the right rpm but only when I back off the throttle a tiny bit. I also installed a governor with weight trimmed off the centrifugal weight but I don't think that would affect my shifting problem. I've done that on several builds with no problem.
    I'm thinking I need to back down the throttle cable adjustment a tiny bit.
    Kevin Ardinger and chryslerfan55 like this.
  2. Budget36
    Budget36
    Not a direct answer, but I’d talk with them and explain it.
  3. miker98038
    miker98038
    What rpm does it shift at if you don’t back off the throttle?
  4. alumslot
    alumslot
    The TV cable is a little too tight. It will shift when you back off the throttle so may be TV is too tight.
