21/32 socket
Discussion in 'The Hokey Ass Message Board' started by kscarguy, Jul 21, 2012.
  1. kscarguy
    kscarguy
    I came across a 21/32 socket in my toolbox. What in the heck does it fit?
  2. Something a hair bigger than 5/8"...?
  3. F&J
    F&J
    I thought they were Ford based size. I have wrenches that my Dad used in his repair shop in the 40s/50s
  4. kscarguy
    kscarguy
    Is it the size of Flathead connecting rod bolts?
  5. There's one in my Dad's toolbox. His Uncle worked for the EZ Washer company(Ringer washing machines), and his father worked for New Process gear. His Grandfather was a Blacksmith and wheelwright. Somewhere in there had to be a 21/32" fastener.
  6. hotroddon
    hotroddon
    A bolt with w 21/32 head - DUH!
    In the old days it was very commomn to have bolt head sizes in the 32 and even 64 range. These days, most common useage would probably be an OLD square head Lag Screw, if it is a 12 point socket
  7. TV
    TV
    If my memory serves me right that is the original size of a model A rod bolt nut.......TV
  8. moefuzz
    moefuzz
    In the cheapest of cheap socket sets they will give you all manor of useless sizes in order to say "99 piece socket set" on the cover.
  9. it will fit on the end of a busted knuckle.
  10. When you round off the head of a 11/16ths bolt, I guareen-damn-tee you that you'll be digging in the tool box for a 21/32s socket to drive onto that rounded bolt head.
  11. JEM
    JEM
    No, that's what cheap 17mm sockets are for...l
    I have a couple early '50s box wrench sets with 21/32 in them, nothing newer and I can't remember ever using it...but I've never been into a pre-1935 engine...
  12. Stefan T
    Stefan T
    from Sweden
    they are for rounded 17mm
  13. garcoal
    garcoal
    i used to work on old aircraft, they had odd sized bolts by our standard. if you look outside of our hobby it might be real common
  14. RichFox
    RichFox
    All the guys who said it was a Ford size are correct
  15. Mr48chev
    Yep, that's the 99th piece in a 99 piece socket set. You don't see that stuff much any more but you used to see it a lot in the 50's and 60's.
    I think I had one come with my original tool set I started out with when I started trade school in 1965.
  16. Andy
    Andy
    I walked into the local parts house about 1972 and asked for a 21/32 socket. The parts man turned to get it and remarked" You must have a Model A". Model A rod nuts.
  17. flathead okie
    flathead okie
  18. wbrw32
    wbrw32
    There is also a 19/32 in my old set of wrenches
  19. TagMan
    TagMan
    I worked at a machine tool manufacturer and 21/32" sockets were used on the heads of bolts for tightening the cutter blade bolts. The bolts themselves were proprietary, made by my company. The guys in the shop were convinced they were designed with the 21/32" hex heads so the employees, both their & their customer's employees, didn't steal the sockets.
  20. kyvetteman
    kyvetteman
    My Grandad worked at a couple of Ford dealerships in the 30's, and his old tools had both the 19 & 21/32 sizes. Now I know why!
  21. Socket sets of the 1930's had quite a few unusual sizes.I have several early sets by Indestro and Duro and one set has 17/32;19/32;21/32;25/32;and 31/32. I also have a couple sets of 4 point sockets from that era.There were several types of drives as well.The early socket sets used a ratchet with a female end rather than the more common(now)male end.They also in addition to square drives had several sizes of hex drives with corresponding ratchets.The breaker bars look like large Allen wrenches with a detent ball in the ends.A handle allows it to be turned into a T handle.
    I have a couple of Snap-On sockets in 17/32 and 19/32 of recent manufacture.I was told that the 19/32 size was for certain GM exhaust manifold bolts.
  22. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Been a while, but I remember the fuel flow motive pump on a Boeing 767 having an oddball ?/32 bolt head..
  23. eaglebeak
    eaglebeak
    Are you serious?
    I'll give you a hint...it won't fit a 7/16" nut.
  24. k9racer
    k9racer
    Most commonly used on Air Conditioners. They use 32 type heads on fastners. Also used on Ice machines. I have also seen on T 56 A aircraft engines mostly C 130 A and H models..
  25. I just talked to Dad, and the 19/32 and 21/32 came from his Dad's toolbox from his days at New Process gear building tank transmissions.
    That Model A rod bolt connection makes me wonder if the Fordson, 9N, 2N, and8N have the same fastener in that application.
  26. George Miller
    George Miller
    from NC usa
    21/32 is the nut size on a model A Ford rod.
