Hey fellow HAMBers! My friend recently bought a 1937 21 stud flathead V-8 from an older guy who has a machine shop. And we were wondering if an 24 stud mercury crank would fit into the 21 stud ford flathead. This would not only make it a stroker but would save my friend John a bunch of money since he could use cheaper bearings and then pistons and connecting rod stuff is alot cheaper too. Well thanks for any help!! Brent
Wake Up? Still partying from last nights Patriots win! Tex Smiths book goes into what is required for that swap. Ive never attempted it tho.
i wasn't there to see if the bearings were poured or not i just know they had to beat them out somehow.
I think it will fit but why wast a merc. crank on a inferior block (for hot rod use) I think the 37 block is the one all the resto guys want for there older fords so they can have insert bearings and 21 studs. Id trade it off for a good 59a or 8ba. unless your trying to build a very early looking car.
It can be done. Two sources with actual experience/pics: Tex Smith's flathead book shows such an engine in a buildup for antique racing. Ron Holleran, probably mispelled there, author of a good flathead book, is on the Fordbarn early V8 group. I know he recently put together a '37 with 8BA crank, which would require all the same machining. Probably a good application for a used up crank that's down to beyond 040--all the diameters have to go way down anyway.
[ QUOTE ] It can be done. Two sources with actual experience/pics: Tex Smith's flathead book shows such an engine in a buildup for antique racing. Ron Holleran, probably mispelled there, author of a good flathead book, is on the Fordbarn early V8 group. I know he recently put together a '37 with 8BA crank, which would require all the same machining. Probably a good application for a used up crank that's down to beyond 040--all the diameters have to go way down anyway. [/ QUOTE ] Bruce, The engine you describe is the one Ron built for my AV8. The engine made a nice street engine. It has the Literio L-100 cam, Thickstun with 97's, .060 0ff the stock heads+some comb chamber re-contouring, some porting in the intake and exhaust, and a 24 lb flywheel. It sounds awesome and goes great down the road. I know most think the 59A and 8BA are the best, but I consider them bellybutton engines. (just joking)
Aaah, '37's are bellybutton motors...wait til the restorers see my '32 engine with Evans heads...LOL By the way, years ago I saw a picture of a '32 roadster pickup running at the Antique-four-ever-four drags in California in an Old Car magazine. This thing was allegedly running a 3 3/16 X 4 '32 V8. It had a skull radiator cap with flapping jaw for extra cool points...
You can do it. Ask the older machine shop guy you got the engine from. I believe that the trick is increasing the diameter of the crankshaft journals. The factory spec for a 1937 engine is 2.3990". For early 24 studs, it's 2.4990", and for '52 and '53 it's 2.4985". However, you're still going to need to use 3-1/16" pistons (or whatever it's bored out to) and not the cheaper and more plentiful 3-3/16" psitons. Unless, of course, you bore it out an additional 0.125"! In which case you'd have a 255 cid 21-stud motor. Very cool. Matching the earlier pistons to a later crank will also require special con rods, because those journal diameters are different sizes, too. So, you can do it, but I don't think that you're going to save money by doing it. --Matt
