216 died while driving home from work
Discussion in 'The Hokey Ass Message Board' started by 1951chevb, Aug 31, 2010.
  1. Big T
    Big T
    from Florida
    The 235 is a much better engine than the 216 as it has a pressure.
    Not all 235s are full pressure. Pre-'53, they are not. '53 is, IF it came with a Powerglide. '54 and after, all are full pressure.
    This link can help ya shop if you go with the swap and yes, its fairly straightforward.
    http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1916-57cast.html
  2. 1936hotrod
    1936hotrod
    from RI/CT
    Gear can be had at almost all real part stores. Take the time to cut it off carefully. Next warm the gear up in a toaster oven(for 25 bucks i keep a new oven in the shop)at under 130 degrees or the water trick. Care to push it on and your done. Pan is the biggest pain.
  3. Shadetree
    Shadetree
    from Va USA
    Thanks for setting this right.
    I wasnt thinking about what I was writing.
    I should have know this, from putting chains together on dozers.
    We use to chill the pins, to get them to slide in the chain links, on the dozer cats
