Projects 230 Dodge cracked engine
Discussion in 'Traditional Customs' started by librado65, Aug 20, 2021.
  1. choptop40
    choptop40
    have experience with the longer engine..you will have to notch the front crossmember , the damper will definitely make contact....ok..so heres the deal....chill out and keep looking for the correct 23 inch motor...they are out there...probably one in your area...if you have fabrication skills , then use either one...or..keep it simple...
  2. The site I go to on Thursdays did have a complete engine in the 1950 as previously replied. Would need a rebuild though.
    Deuces likes this.
  3. birdman1
    birdman1
    They were used in M***ey and Oliver combines too.
  4. goldmountain
    goldmountain
    The only important information I can add is to unbolt the flywheel from the engine before trying to pull out the old engine. It won't clear the bellhousing.
  5. KenC
    KenC
    And lots of industrial equipment, forklifts, air compressors etc.
  6. librado65
    librado65
    Plans have been delayed a little bit. My first cousin and his family got sick and then unfortunately caught covid and he has been in the hospital and finally p***ed away from covid this weekend. He helped me out with the car when it was first delivered and put on the fender skirts on for me because he said it looked better with them on.
    Anyways....
    Is there anyone near or around Trinity, Alabama, USA. The gentleman with the engine only wants a $400 check or money order as payment. I tried to discuss transferring money through PayPal but he said he is not familiar with it. I do not have the time to travel currently. I obviously do not know the guy since he is from the internet and I do not feel safe sending a check to someone online without seeing the engine or the possibility of being scammed.
    I would like to see if someone on here possibly can go check if the engine is real, for me, please
  7. TerrytheK
    TerrytheK
    @anthony myrick
    He's from "somewhere in Ala" and posted earlier in this thread. If he isn't close to Trinity maybe he knows someone who is?
    I'm in Minnesota so not much help there, but it's a thread bump for you.
    Sorry for the loss of your cousin.
    librado65 likes this.
  8. Hank37
    Hank37
    My friend had a 1947 Plymouth and put a 1957 Plymouth engine in it was a direct fit , no problems.
  9. librado65
    librado65
    Thanks.
  10. HXFOUR
    HXFOUR
    Im about to remove a 23" 230 flathead 6 engine from my car, it needs to be rebuilt as something had happened to an exhaust valve (Stuck valve, rings, not sure) but the block is rebuildable. Also have a Offy intake, dual carb setup, dual exhaust manifold. Its in Toronto, Canada but if theres a way to get it to you, we can chat.
  11. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Good luck getting there. I'm sure it can be found. I'm also sure that if I owned that car I'd want to be driving it
    All day long.
    ( covid has cost us way too much )
