235? 216? none of the numbers seem to make sense
Discussion in 'The Hokey Ass Message Board' started by nashvegas99, Feb 9, 2011.
  1. Rickybop
    Rickybop
    You can't use an old torque-tube-type automatic trans with the open driveshaft.
    Maybe re-sell the 235, and buy a 1963 or later Chevy six that a TH350 will bolt up to.
    What kind of vehicle are you working on?
  2. nashvegas99
    nashvegas99
    Ibuilding an old version of a t bucket. using the stuff from t-bucket parts 4 u. Ok, what do I type in to search for parts for and gaskets for on this transmission?
  3. nashvegas99
    nashvegas99
    I've been looking around and I think that after going back and forth 200 times, that this is a chevrolet 341 transmission. Is that the "same" as the muncie 3 speed? THe reason I ask is that Hurst sells a Master Shift Shifter kit that will put the shifter for the 3 speed in the floor
  4. nashvegas99
    nashvegas99
    would someone educate me? Ok, from the front to the back...there is a lever sticking out of the bellhousing =?? Then there are 2 small slotted shafts. They =??? from front to back. It has the 4 bolt cover so I'm going with a 341.
  5. JohnEvans
    JohnEvans
    from Phoenix AZ
    The lever in the bellhousing is the clutch release lever. Yes that is the Muncie 341 3 speed. About any universal 3 speed floor shifter can be made to work . A Hurst would be the best working one.
  6. nashvegas99
    nashvegas99
    a very idiotic question here...but this is a 12 volt system for a 1956 235 right?
  7. miltstrk
    miltstrk
    I think that I still have a cast iron power glide that came attached to a 235 that I bought. Contact me off line if you are interested in this transmission.
