Technical 235 engine pulling
Discussion in 'The Hokey Ass Message Board' started by 68caddydaddy, Dec 3, 2015.
Tags:
  1. 68caddydaddy
    68caddydaddy
    Hi gearheads, I want to pull the 235 engine (for rebuilding purposes) from my '54 Chevy handyman WITHOUT pulling the ****** . I removed the brace and radiator allready, the 235hood is way up, car is on jack stands. How hard is it to loosen the bolts that connect the ****** to the engine. Can I reach them all when I'm underneath the car ? Please advise ...
    Does the engine have to be pulled if I want to change the rear rope type sealing of the cranck shaft. Imagine this lying under the car ..... Tnx guys
  2. Hnstray
    Hnstray
    from Quincy, IL
    Yes, the trans bolts can be removed from under the car. I can't recall for certain if the cars had the bottom two bolts accessed from inside the bell housing. But, either inside or outside, they are readily removed. It's been a long, long time since I had my '51 Chevy, but I seem to remember the floorboard has a removable section of the transmission hump to improve access to the top bolts. If not, you can use tools to reach the upper bolts, such as a long extension with a socket and ratchet.
    You will need to provide some support under the trans to hold it up when the engine is pulled out.
    Ray
  3. 68caddydaddy
    68caddydaddy
    I dont know if there is an excess hole in the hump, that would be easy to access
  4. tb33anda3rd
    tb33anda3rd
    it will be easier to take the ****** right out, or pull it with the motor. you can do the rear main wiht the engine in.
  5. donsz
    donsz
    I don't have a lot of experience with the 235 as some others do, but the times I have pulled the six cylinder engines (235/261) out of my truck (which has a lot of engine bay space), I would agree, pull the trans first..It isn't much to pull the trans anyway. It makes it much easier to remove and re-install the engine (and minimize mis-alignment the possibility of damage to the trans). I don't think I would attempt it without pulling the trans first.
    don
  6. saltflats
    saltflats
    from Missouri
    If it is a auto trans you will have to pull them together.
  7. 302GMC
    302GMC
    from Idaho
    Of course the engine OR trans can be pulled separately. You think transmission shops were pulling the engine to rebuild the trans ? The engine has to turn - seized parts make it a new game ...
  8. Is it a glide or a 3 speed? if it is a 3 speed you just remove the 4 bolts holding the transmission to the bell housing, like @Hnstray said the bottom two bolts are probably accessed from inside the bell housing. there is an inspection plate on the bottom of the bell housing that you will no doubt have to remove.
    If it is a powerglide car you can remove the engine without the transmission but it is a pain in the **** if you have never done it before, you will have to drop the inspection place from the bell housing and remove the torque converter bolts, this done by turning the engine until you have removed them all. You will have to unbolt the bell from the engine and remove the starter ( one bolt inside the bell housing) as well as make sure that all the bolts have been removed from the adapter plate that goes between the engine and the bell housing. Some if this will be done from above and some from underneath.
    Or as @saltflats suggested pull them both as a unit.
    You do need to remove the hood it will just make life easier for you.
    Hnstray likes this.
  9. 68caddydaddy
    68caddydaddy
  10. 68caddydaddy
    68caddydaddy
    235 Engine pulling
    Are these the bolts that have to be removed to pull the engine ? (6x)
  11. 54fierro
    54fierro
    from san diego
    That doesnt look familiar to me so I ***ume you have the powerglide(?).
    Not familiar with those but if it is somebody earlier suggested pulling them together.
    Did want to mention that not all these cars had the access hole in the hump. My 54 doesnt.
