235 Vapor Lock, need advice
Discussion in 'The Hokey Ass Message Board' started by 1927 Death Trap, Jun 19, 2013.
  1. 1927 Death Trap
    1927 Death Trap
    from CT
    I run a 235 IL6. Patrick's mild cam, 848 head, Langdons 2 carb set up, Mallory dizzy. In traffic, or any time it idles for more than 10 minn it starts to vapor lock. Temp is only at 195 tops. I swaped jets, ran like ****,backed out timing and added, no good. Any ideas would be great. Thanks
  2. Styleliner
    Styleliner
    Old timers used to put clothes pins on their fuel lines... Or clamps of some sort. I bought a ford with a six in it and noticed 4 clothes pins wooden ones.... When I asked about them he said they prevented vapor lock. I took them off thinking old wives tale, but sure enough I had to put them back on.... And it worked.
  3. Styleliner
    Styleliner
    I know it sounds crazy.use 4 or 5 spaced about your fuel lines under the hood. They act as a heat sink.
  4. Lostinwisc
    Lostinwisc
    I've had this happen in the past, get a hold of a fuel filter that has a extra ****** on it (79 jeep ? ) and run a return line back to the fuel tank -- gas will always be flowing & no more vapor lock . Clothes pins on fuel line-or tin foil on fuel line --never seen it work --jmho .
  5. Styleliner
    Styleliner
    That does sound like a more sound idea... But won't it impede flow to carb ?
  6. bobss396
    bobss396
    The clothespin trick works since wood is a poor conductor of anything but fire.
    I'd look to route the fuel line away from anything that makes heat. I run a big Holley fuel filter along my frame rail before the fuel pump, this ***ists in cooling the fuel.
    Other tricks, install a cool can and route the gas through that. Do you have room to add phenolic carb spacers and not disrupt your linkage? Lastly, louver the hood and inner fender wells. Looks *****in' even if it doesn't work.
    Bob
  7. R Pope
    R Pope
    Timing and jetting have no effect on vapor lock.....
  8. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Wooden clothes pins has the traditional look and work good too!
  9. 54Buick48D
    54Buick48D
    from Maryland
    electric fuel pump at the tank.
  10. mgtstumpy
    mgtstumpy
    Blocked or obstructed fuel tank vent was my issue. Once line was purged I had no further problems.
  11. Lostinwisc
    Lostinwisc
    Nope won't impede flow to carb--or it didn't on the times I've employed it.
    Tin foil & clothes pins do look kinda neat tho , as dose a cool can -- did make one outta a Folgers can complete with plastic lid --use to put ice in it
    -- to bad it didn't cure the vapor lock -- but it did look cool .:D
  12. Curt B
    Curt B
    Make sure the fuel line isn't touching or too close to a heater hose. Routing the in line immediately away from the block and over to the frame rail can help as well as covering it with plastic wire loom.
