Technical 235 vs 235
Discussion in 'Traditional Hot Rods' started by 47streamliner, Nov 3, 2016.
  1. 47streamliner
    47streamliner
    from Huntley il
    Yes you read that right
    I have the opportunity to buy a 235 from a 57 belair or a 235 from a 1960 belair . Both are power glide cars .
    Both are priced about the same and would be going into a 1950 Chevy
    Is one preferable over the other ?
  2. cavman
    cavman
    I don't think there is a lick of difference. Get the cleanest one inside.
    LOU WELLS likes this.
  3. tinsled
    tinsled
    For one thing 1960 has hydraulic lifters, while '57 are mechanical. Thus the newer runs smoother and needs less maintenance.
  4. LAROKE
    LAROKE
    I'm certain the '57 Belair also has hydraulic lifters. The solids were in the truck engines.
    need louvers ? likes this.
  5. Pick the cleaner of the two, can you pull valve covers to see ?
    Both are hydraulic lifter engines.
    Johnny Gee likes this.
  6. 47streamliner
    47streamliner
    from Huntley il
    Yup they should let me . The 60 235 supposedly has the 848 head
  7. The '848' will bump up the C.R. a bit. My 235, seen in my avatar, has the 848, as well.
  8. jcmarz
    jcmarz
    from Chino, Ca
    The 60 will have more power since it had to propel a heavier car.
  9. Rusty O'Toole
    Rusty O'Toole
    Looked it up for the hell of it. The 57 lists at 140HP and 8:1 compression, the 1960 at 135HP and 8.23:1. I wouldn't let that sway me. I would go more by mileage, condition, completeness and price.
  10. Atomic Kustom
    Atomic Kustom
    1953 powerglide cars and '54 on up were hydraulic lifters
    LOU WELLS and Johnny Gee like this.
  11.
  12. 1954 STICK 235 and 1955 STICK 235 still had solid lifters, in p***enger cars.
    The switch to ALL hydraulic lifters in the 235, came in 1956, for p***enger cars.
  13. 47streamliner
    47streamliner
    from Huntley il
  14. 47streamliner
    47streamliner
    from Huntley il
    I tried to look up the casting number on the 60 and didn't find it on the listings - 3836848
  15. Last edited: Nov 4, 2016
