235 with unexplainable knock!!!!!
Discussion in 'The Hokey Ass Message Board' started by aktattoo, Feb 27, 2009.
  1. Locomotive Breath
    Locomotive Breath
    from Texas
    I figured the rod would be similar to a 270 / 302 Jimmy, oh well maybe the bolt loosened up or broke as someone suggested. Pin could also be loose in the piston or the skirt may have cracked.
  2. kkoacolonel
    kkoacolonel
    from Union,NJ
    I would check the wrist pin.Mine has been knocking for the last 24 years I've owned the car.Still drove the **** out of it.
  3. aktattoo
    aktattoo
    your oil pressure in a new rebuilt 235 should be at least 45 lbs and may drop significantly at idle but with higher rpm's oil pressure especially in a fresh rebuild would be very high
  4. hotrod-Linkin
    hotrod-Linkin
    have you checked the trunk to see if ya locked the neighbors kid in?
  5. I had a 235 in a '55 F1 p/u do the exact same thing!
    Snowing,traffic, I'm trying to get my kid to the daycare! Drove it until it got hot from not having a belt, let it cool some, and drove it home.
    I really think it ran better on five! Mike :eek::eek:
