Projects '24 T Roadster build
Discussion in 'Traditional Hot Rods' started by Anderson, Aug 21, 2012.
  1. Am I just looking at it wrong, or is your water neck missing the neck? o_O
  2. Leon Sandcastle
    Leon Sandcastle
    I don't see hoses on there at all.... yeah what's up with the water outlets?
  3. orangeamcs
    orangeamcs
    Looks like the beginnings of a custom waterneck. It looks to be in mockup since no bolts in the neck or intake. A stock neck probably interferes with everything.
  4. **** man this car is so neat!
  5. What a jewel!
  6. pumpman
    pumpman
    Yup, there is nothin like "done right"!
    volvobrynk likes this.
  7. Equipped28
    Equipped28
    Man this thing is looking killer.
  8. Dan Hay
    Dan Hay
    Your going to finish things this weekend that I've been working on since August on mine! Go man go!
  9. Sakke
    Sakke
    from Finland
    Your T just get better and better all the time !! Great Work !!
  10. Kiwi Tinbender
    Kiwi Tinbender
    Nice, Really Nice. You could always sell me the Pullmax, then you maybe could afford to finish that little gem properly.....(!!!).....:D:D:D
  11. Equipped28
    Equipped28
    It's great having your car at work. Ive brought my T into the workshop and I've got more done on it in 3 weeks than I have in 6 months!
    volvobrynk and Anderson like this.
  12. Outback
    Outback
    from NE Vic, Oz
    Wow! Looking great!
    Sent via carrier pidgeon & smoke signals with the HAMB App
  13. Koz
    Koz
    Following this all the time. Looking great. I can't wait to see it with the body painted and one the ch***is for that last time. Keep pounding away!
  14. Beau
    Beau
    I love the color combo. Keep up the fine work.
  15. The 39 guy
    The 39 guy
    This Hot Rod just keeps getting better! I hope you do a little video so that we can share the start up with you.
  16. X38
    X38
  17. Refreshing, cl***y, and some smart detail that makes it a stunning little car, certainly a credit to you and your persistence.
    Cheers,
    Drewfus
    Outback likes this.
  18. charlesf
    charlesf
    Fabulous work!
  19. El Hueso
    El Hueso
  20. Strange. I just checked my 303 that's out in the garage. The block only has one bolt hole, and the distributor is a simple wishbone shaped hold down. I know both my 324's have the same style hold down, and I believe my other 303 is the same (though I don't have it here to check). Regardless, it looks like you've sorted out a solution that will work just fine.
  21. Six Ball
    Six Ball
    from Nevada
    We can figure all of that out after LSR. Just "getter' done." I put in a '50 303 in my first car, a '38 coupe, in '61. It had an Offenhauser 3X2 and I do not remember what held the distributor in place. I do though have vivid memories of being towed for the first startup and being engulfed in balls of flames as a result of progressive aggressive carb priming before we figured out there was supposed to be a fuel pump lobe bolted to the front of the cam. Hell, we were Flathead guys and had never seen a box full of Olds parts. :confused:
    volvobrynk and Jimmy B like this.
  22. Kiwi Tinbender
    Kiwi Tinbender
    This little car is so cool it hurts.......:eek::D
  23. von Dyck
    von Dyck
    Remember that the firing order is 1-8-7-3-6-5-4-2 ! These engines came with the 4-7 swap right from the factory!
  24. Six Ball
    Six Ball
    from Nevada
    I've only been to LSR once. I wish it was this year.
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm thinkin double deep gloss black
    kidcampbell71 and lothiandon1940 like this.
  26. Paul
    Paul
    Editor
    Looks great!
    The '49 distributor hold down was a two piece affair, I can post a picture later for the curious, but what you have there will work fine.
    Love this build!
  27. Austinrod
    Austinrod
    from Austin
    Old skool ***ian red or Tahitian red how ever you want too call it
    volvobrynk and Speedy Canuck like this.
  28. Six Ball
    Six Ball
    from Nevada
  29. Last edited: Apr 9, 2015
