Hot Rods 25/32 socket
Discussion in 'The Hokey Ass Message Board' started by RmK57, Oct 11, 2020.
  1. Yes, 25/32 is almost exactly 20 MM, but 15/32 is under a half inch so not 15 MM. It's actually just a hair under 12 MM.
    I still use a fair bit of metric so when you wrote 15 MM I knew that didn't sound right.
  2. DDDenny
    Don't pitch those oddball sockets you may need to press out some u-joints or need to weld up some Rube Goldberg tool.
  3. I have a double ended open end wrench that is 7/8" and 25/32".
    I found it behind the seat of my '41 Ford Truck.
    Working on the dash of my '50 Ford an 11/32" nut driver or socket was indispensable.
  4. TrailerTrashToo
    TrailerTrashToo
    A magnet sticks to mine. The manufacturer's data plate is weather faded,
    saltracer219 likes this.
  5. PhilA
    PhilA
    Rust.
    Deuces likes this.
  6. willys36
    willys36
    Begs the question why don't they standardize a ton of stuff on a given "cl***" of car/engine like sparkplugs, tie rod ends, fuel and oil filters, air cleaners, bolt sizes on common parts like exhaust manifolds, bell housings, etc., etc., etc.
    1940Willys likes this.
  7. carbking
    carbking
    Then the aftermarket could sell it cheaper!
    Jon.
  8. mike in tucson
    mike in tucson
    from Tucson
    Only good ues of a 25/32 socket is to use it in a press as a spacer.... maybe for a small u-joint?
  9. stillrunners
    stillrunners
    from dallas
    Think that's the one I'm missing........wonder if it got thrown.........?
  10. tubman
    tubman
    I am really into "traditional" ignition systems and have run into a lot of 11/32" nuts. I would even say that they are common.
  11. TagMan
    TagMan
    Maybe used in industry to deter theft. Who would risk their job for a 25/32 socket ??
  12. saltracer219
    saltracer219
    Sorry, I ment to say that those Utility Boxes were mostly all Aluminum and very well constructed, the fasteners are steel.
  13. indcontrols
    indcontrols
    The 11/32 is standard for 8-32 nuts, I use them all the time - I think the 25/32 is to keep social distancing between 7/8 and 13/16... Actually I'm pretty sure I used my 1/2 drive one as a spacer for a bracket on my golfcart...
    VANDENPLAS and Budget36 like this.
  14. Budget36
    Budget36
    I know what I have to do now. Tomorrow is my only day off this week, and I’ll spend a few hours hunting down all the oddball /32 wrenches and sockets I have and post a pic of them.
    Another way I have to waste perfectly good time on something meaningless
    Thanks all!
  15. Atwater Mike
    Atwater Mike
    OOOPS!!! Working on my F100, just stopped to read for a moment: I meant 19/32". (15mm)
    Sorry, guys. (no google, just my realization over 60 years of 'Hey, this socket fits VW head nuts...' LOL
    Center of the Galaxie likes this.
  16. Atwater Mike
    Atwater Mike
    Right. But I don't MEAN to... (I meant 19/32" = 15 mm. Whew!)
    VANDENPLAS likes this.
  17. Budget36
    Budget36
    Psst, hey Mike. Take the decimal inch number and multiply by 25.4, than will give you mms. Take the MMS and divide by 25.4 and that will give you the decimal in inches.
    Google is easier tho, lol was
  18. BamaMav
    BamaMav
    from Berry, AL
    I always thought those odd sockets were to pound on a nearly rounded bolt or nut. You know the ones, the ones you rounded with a worn out 12 point socket or an adjustable Crescent wrench!
    loudbang and Budget36 like this.
  19. gsjohnny
    gsjohnny
    how about tap sizes. years ago i rebuilt my fathers farmall h engine. the radiator studs were not 7/16 or 1/2 thread, they were in between. this is early 40's. cornbinder made their own stuff so you had to buy from them. damn line tickets......
    Truckdoctor Andy likes this.
  20. TrailerTrashToo
    TrailerTrashToo
    My turn to be unclear - My 1952 service bed is steel, no aluminum found.
  21. I cut mine in half and ended up with two 25/64". Ideal for flux capacitor end caps.
  22. seb fontana
    seb fontana
    from ct
    Found a Craftsman open end 11/16 & 21/32.
  23. The S terminal on a Chevrolet starter used to take an 11/32” socket to get the nut loose or to tighten it up.
  24. I have some oddball sockets as well as some wrenches that are in /32s. I don't remember how or where I got them, and have only rarely ever used them. When I have used the sockets, it was to grab a corroded nut or bolt, when the right size was too loose.
    Bob
