Projects 26/27 Model T Touring Build (formally Unknown A)
Discussion in 'Traditional Hot Rods' started by Jax2A, Nov 10, 2021.
  1. Jax2A
    Jax2A
    After major life changes I’m finally getting back on my hot rod project that started with a model a frame and no real plan. Now I’m back and more focused and have a traditional build in the works. Basically I’m going for a car that someone started in the forties and it just kept getting different mods up into the 60’s… basically I’m allowing myself to have mods and parts through 1966 (the year I was born). If that’s not traditional enough for this sub-forum let me know and I’ll move it.
    I’ll be documenting the build on my YouTube channel too. Let’s face it I’m not Iron Trap Garage but I hope you’ll consider watching along and subscribing (Link at the bottom of this post)
    Here’s what I have so far:
    26/27 Ford Model T Touring
    Model A Frame & Front end, spindles, etc
    1952 Flathead/repro dual carb manifold
    1946 Ford truck open drive banjo
    Juice brakes
    4 Holley 94’s (hopefully I’ll get two good ones out of them)
    59 Sprite dash and Smith gauges and generator for the mechanical tach
    15” x 5” smooth front wheels 15” x6” smooth Lincoln Premier wheels for the rear
    Split 40 something wishbones
    Pair of Dietz 820D headlights and 50’s Lucas taillights
    And I can’t remember what all else right now so you’ll just have to subscribe and follow along to see how it all comes out!
    Hope too hear from folks, I could use the encouragement!
    Here’s the YouTube link:
    Outback, Tman, trevorsworth and 4 others like this.
  2. 2Blue2
    2Blue2
    This will be a fun build, looking forward to it.
    Jax2A likes this.
  3. 55willys
    55willys
    Cool, check out the one I am building
    kidcampbell71 and Jax2A like this.
  4. sloppy jalopies
    sloppy jalopies
    talk to the boys about 94 carbs...
    something about multi carbs, power valves and vacuum...
  5. Jax2A
    Jax2A
    I’ve already checked it and following. Definitely a cool build.
  6. Jax2A
    Jax2A
    I’ve read a lot of old posts about them…. Multi carbs lower the manifold vacuum so you have to use power valves that open at lower vacuum or else they’ll stay open and you run rich all the time. Seems to be the consensus to run slightly smaller jets as well. That’s the plan at least for now.
    Outback likes this.
  7. Jax2A
    Jax2A
    The next chapter of my 1927 Ford Model T touring hot rod story is up on YouTube!
    Hope you guys will want to check it out! Feel free to comment with criticism, encouragement or words of advice because I need them.
    I know I have a lot to learn and a long way to go but if you’re so inclined please consider subscribing and following along… Thanks!
  8. Jax2A
    Jax2A
    Uploaded another video of a side project for my hot rod…
    Outback likes this.
  9. Jax2A
    Jax2A
    Been a minute but I’m working again…
    Outback likes this.
  10. Jax2A
    Jax2A
    Baby steps are better than no steps…
    Outback likes this.
  11. Jax2A
    Jax2A
    Still plodding along… converting my 1946 truck parallel leaf open drive banjo to transverse Model A spring:
    Outback and simplestone like this.
  12. Jax2A
    Jax2A
    I made a jig/fixture and taught myself how to reverse the spring eyes on my front and rear springs!
    Outback likes this.
  13. Jax2A
    Jax2A
    Slow progress is still progress…
    simplestone likes this.
  14. Jax2A
    Jax2A
    And the build goes on….
  15. Jax2A
    Jax2A
    Still trying to get my rear on the ground… converted my 46 banjo to slip-over drum brakes.
    Outback likes this.
  16. Jax2A
    Jax2A
    Still working on my 46 banjo… this time I’m tearing into the brakes;
    Outback likes this.
  17. Jax2A
    Jax2A
    The continuing saga of installing my 46 banjo has ended! (for now)
    Outback and Fjant like this.
  18. Jax2A
    Jax2A
    Trial and error continues but I’ve finally got a rolling chassis now that I got my front end installed…
    Outback and panhead_pete like this.
  19. Jax2A
    Jax2A
    For better or worse I built the transmission mount out of a piece of 46 truck crossmember;
    Outback likes this.
  20. Jax2A
    Jax2A
    Got my flathead V8 mounted in the chassis. Made the front V8 motor mounts out of the rear motor mounts for the Model A four cylinder:
  21. Jax2A
    Jax2A
    Just an updated picture of my build (but I’m still putting the details on my YouTube channel) since I haven’t updated here in some time. This spring I found an old 3” dropped Model A axles so I reworked the front end, I got all my shocks mounted, headlights too, started putting the body back together and figured out the steering. Still a long way to go but at least I’m making slow progress.
    roadwarrior84 likes this.
  22. Buy the good biscuits, the ones with the metal band. The ones you have will collapse in no time.
  23. Jax2A
    Jax2A
    The motor mounts? Yeah they’ve already collapsed, where do you get the ones with metal bands? I haven’t seen them.
    Outback likes this.
  24. CE used to have them. I would try Pete and Jakes. I think I have some that I cut bands for out of tubing on the shelf as well. Guys have also replaced with UMHW plastic or hockey pucks.
    Outback likes this.
  25. Jax2A
    Jax2A
    Lol, as an ex hockey player I was already considering making my own out of pucks! Thanks!
    Tman likes this.
  26. Jax2A
    Jax2A
    Still plugging away…
    simplestone, Stu and dwollam like this.
