Yeah, I know, there is one in the classifieds too. I need a 26-27 T coupe driver's side door. Hook me up!
<font color="red">Those fuckers at Model t Haven suck!....I tried in the past to get stuff from them.....they never even returned my emails!!!!!! R E D M E A T </font>
<font color="red"> I tried to get ahold of them 3 times never even a response!..........they only had the same pics for like 3 months ........prices were way cheap as I remember.......i payed twioce what they wanted for better doors then I got!......to bad they never got ahold of me! R E D M E A T </font>
El Caballo, I don't know of a door but I just wanted to make you aware that this coupe door is the same as a '28-'29 closed cab pickup door. Reggie
I've got a Passenger door from either a T Coupe/Tudor or A pickup that is different! The Garnish molding has a different bolt pattern. The Big embossed V under the window isn't there and the door latch pocket isn't a pocket. The door latches do not swap without modifiying them. The hinges are slightly different too but bolt up the same. The outer skin is IDENTICAL. The hinges all line up. I was told by a couple of people that the 28-29 truck doors are slightly different than the 26-27 T's but they would work. Both style doors use the 3 bolt window regulator and are dimensionally the same.I think I may have an early 26 door. Guess i should go on the fordbarn and talk to a resto freak about this.
Yeah, there is a difference but the sheet metal is the same. The reason the drivers door is so hard to find is that the farmers took these doors off the A pickups and threw them in the holler, that way they could jump in and out alot quicker.
Try this guy. http://www.rodsandrides.com/ He has a room full of Model T stuff He brought back from NM and AZ last spring.
model t haven is pretty fucking cool. stacks and stacks of frames sheetmetal younameit. they let me roam around in it like a big playground. nice enough.
