Projects 26 roadster build; Bang Bang
Discussion in 'Traditional Hot Rods' started by h.i., Nov 4, 2012.
  1. h.i.
    h.i.
    from denver
    The shell is not bad at all, and it was cheaper than some of the glass ones!
  2. Morrisman
    Morrisman
    from England
    Cool build, nice to see these little details used.
    Can anybody advise me of the correct way to adjust these rod ends? I've retained them on my RPU and I'm not sure how much tension to put on the screwed in part before slipping the split pin in.
  3. PINEAPPLE
    PINEAPPLE
    Morrisman, my Ford f1 manual says to tighten the cup and spring against the ball until it stops, then back it off until the slot lines up with the hole for the cotter pin. I greased the bejesus out of the cups and ball, then followed this procedure. Seems to be working fine. Hope this helps a bit.
  4. Morrisman
    Morrisman
    from England
    Thanks for the info. When you say tighten until it 'stops', is that when it touches, or cranked down as far as it will possibly go? I screwed mine until they touched then in until the holes lined up.
    But you can see it move when I turn the steering etc. I feel it should be tighter. The screw is pretty much flush with the end of the housing.
  5. PINEAPPLE
    PINEAPPLE
    I cranked it down as far as it would possibly go, that's how I understood it should be. Seems right to me.
  6. oj
    oj
    You guys useing the steel or newer teflon seat for he ball? I just wonder if it makes any difference when tightening.
  7. PINEAPPLE
    PINEAPPLE
    Steel seat, have not seen the teflon part. Even with the steel and grease, tightened all the way down then backed off, the action is still fairly smooth although not floppy and loose if that makes sense.
  8. 26 T Ford RPU
    26 T Ford RPU
    I have been trying to find some info on that joint,My 35&37 Willys have them on the drag links.First you must check that the ball is still round as they do wear and it has to to tight enough so the spring cant compress and thet the ball jump out under load.Hope this my help you, cheers,JW
  9. 26 T Ford RPU
    26 T Ford RPU
    H.I. , sorry to use you thread .I did a search and on a Model A rod end the spring should be compressed 25%.JW :)
  10. h.i.
    h.i.
    from denver
    Compressed 25% does not sound like enough to me. Following the procedure in the manual might get you 75% COMPRESSED and 25% left over. The parts need some room to move. We will be using the procedure in the book, thanks pineapple.
  11. daddio211
    daddio211
    Hitchin' a ride. I like where this is going!
    Sent from my DROID device using the TJJ mobile app
  12. qzjrd5
    qzjrd5
    from Troy, MI
    Great build thread. Man, this makes we want to build a T roadster!!
  13. h.i.
    h.i.
    from denver
    Thanks guys. We got the new driveshaft built and the torque tube back in the other night. Lots of machine shop pics to come... stay tuned
  14. h.i.
    h.i.
    from denver
    When we left off last, we had shortened the torque tube. Now on to building the drive shaft. We did a lot of survey work, then chopped the original shaft. Put it in the lathe to clean it up for the press fit:
    The raw material for the lugs to fit the shaft to the new tubing:
  15. h.i.
    h.i.
    from denver
    machining the lugs:
  16. h.i.
    h.i.
    from denver
    A little more work to clean it up:
    shaping
    goon squad
    One down!
  17. h.i.
    h.i.
    from denver
    Now we press this end on to the shaft
    In the "press":
    Looks pretty, ready to weld:
    brEad likes this.
  18. 117harv
    117harv
    Nice job on the parts and the build.
    Off the wall sticker and pinstripe...a lathe with style;)
  19. h.i.
    h.i.
    from denver
    Thanks a million to my friend pineapple. None of this would have happened without him. He finished up the other end, pressed it on and welded everything up during the week. Then he brought everything over and we installed it the other night.
    He even drilled an tapped it for a nice zerk
    brEad likes this.
  20. h.i.
    h.i.
    from denver
    We had to pull the motor and get the rear aligned. It was a bit tricky to get this installed, but it fit perfect. More thanks to pineapple.
    OFT and brEad like this.
  21. h.i.
    h.i.
    from denver
    So that's where we are right now. Still have a long way to go. Thanks to Pineapple, LSR2909 and Zombie Lips for all the help. More pics as we progress. Probably move on to the front end next week.
  22. Strange Agent
    Strange Agent
    Awesome build. I'll be following this one.
  23. h.i.
    h.i.
    from denver
    Thanks man. If I had known how hard this stuff really is, haha. It looks so easy on the internet!
    brEad likes this.
  24. PINEAPPLE
    PINEAPPLE
    Zombie Lips...:D:D good times!!
  25. daddio211
    daddio211
    Yeah, um, you don't seem to be struggling through this at all.
    And if you think the internet makes it look easy you should watch that TV show with Chip Foose where they build a whole car in AN HOUR!!!
  26. oldebob
    oldebob
    from Spokane WA
    Just got onto this build. A great traditional hot rod and very interesting as so much of the stuff you are doing is not "by the book" . Really enjoying watching this progress.
  27. h.i.
    h.i.
    from denver
    What? You mean there's a book?*****.
  28. h.i.
    h.i.
    from denver
    Zombie Lips selfie:
  29. h.i.
    h.i.
    from denver
    Tonight I tackled a problem that's been bothering me for a while. I could not decide what to do for the front wishbone mounts. I finally decided to make them from scratch from half inch plate and was all ready to start carving them out when I stumbled upon some stuff in the JAWA pile. I'm really glad I don't throw anything away, ever.
  30. h.i.
    h.i.
    from denver
    If you can guess what they were, well, you need to spend less time on here.
    brEad likes this.
