Technical 26 roadster fuel sending unit????
Discussion in 'The Hokey Ass Message Board' started by nailheadjay, Mar 14, 2015.
  1. nailheadjay
    nailheadjay
    I have an aluminum fuel tank.. there is a stewart warner sending unit in there.. on top is a plastic fitting that has 2 pins in it....im guessing one might be for a ground...and the other to the gauge... any ideas??? when I took apart one wire goes to the bottom on the unit where float is the other is soldiered to the top spade of the plastic ***embly .. hmm .. any ideas
  2. 325w
    325w
    Most times the center pin is the gauge sender wire. It works off the reostate.
  3. MORRISGAUGE
    MORRISGAUGE
    The post that has the wire to the rheostat/float arm is the one for your gauge. If the other is soldered to the frame then it is a ground connection. Most senders gain casual ground through the tank and mounting hardware, but the additional post provides a solid connection.
