trying to fire up the roadster...all new stuff...im not getting any spark... i have power to the coil..brand new.. and it is getting really warm?? could it be bad?? i unplugged the coil wire and with engine turning i put a test light in there and no light came on.. dont know if thats how you test it?? any ideas...new petronix dist.. all hooked up correct
This might be some of your problem. Do you have current to the coil at all times? The coil should only see current when the ignition switch is in the "crank" or "run" position. Recheck your wiring. If it's getting current all the time that would explain the coil getting hot and the resulting meltdown.
yea. sbc.. i had the coil grounded... that was a mistake! i put a new one in.. only grounded by the dist.. and it fired right up... live and learn
