Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    Finished the floor under the seats and bolted the bombers into place. Also made and welded in seat belt anchors.
    No pictures this time.
    A funny thing happened, bolting the seats in and then sitting in the drivers seat was like getting a couple extra inches of leg room. :)
    I guess the seat was not where it was supposed to be while I was setting it all up. A bonus.
    The seating position is nice and I sit down in the car enough that the top edge of the body behind the door is at my armpit level.
    Great for a T I think. :cool:
    Larry.
    AndersF likes this.
  2. Dick Stevens
    Dick Stevens
    Sounds good, pretty soon you will be prepping for making it shiny. :cool:
  3. Bulletnose26
    Bulletnose26
    All very positive news. Glad to see the great progress.
    The side profile photo looks excellent.
    I'm sure, after mounting the seat, and sitting in it, you had a smile from ear to ear.
  4. Really enjoying this thread, the Y-Block is a really great choice.
  5. 57 Fargo
    57 Fargo
    I can't wait to see the finished product Larry, it will be stunning no doubt!
  6. 26 T Ford RPU
    26 T Ford RPU
    I bet you were making noises while sitting in there:D:cool:JW
  7. Blue One
    Blue One
    from Alberta
    Shhh don't tell :D I thought of getting out the video Tim made for me of the run in when he built my Y block and just sitting there listening to it run :D :cool:
  8. I would say you not the first to sit in their car and make engine noises and you certainly won't be the last. Hell I caught myself making funny noises while sitting on the pondering stool beside my Roadster while out in the garage. So all is normal here, mate...:eek::rolleyes:o_O:)
  9. Blue One
    Blue One
    from Alberta
    Here's what I would rather listen to instead of making noises :D :cool:
    The very healthy engine built by Tim McMaster that is waiting to go into the RPU.
    Larry
    daddio211 and 26 T Ford RPU like this.
  10. 26 T Ford RPU
    26 T Ford RPU
    Very nice Larry:cool::cool::D JW
  11. Blue One
    Blue One
    from Alberta
    I needed to find a location for the battery.
    I didn't want to put it in the small section of bed left after the gas tank was mounted, and I could not put it under the seats or floor, just no room :confused:
    I picked a small Deka battery, an AGM battery identical in size to the Braille 3121, possibly made in the same factory as the Braille.
    The Deka will be plenty strong for the RPU. It also is relatively small and can be mounted lying on its side.
    I have a small space on the side of the rear frame kick up behind the side panel I had fabricated that proved to be a perfect location for the battery.
    I fabricated a battery "box" and mounted it to the side of the frame kick up behind the panel.
    It fits nicely, is tucked up out of harms way and hidden fairly well.
    Larry.
    battery box 007 (2).jpg battery box 002 (2).jpg battery box 003 (2).jpg battery box 004 (2).jpg battery box 005 (2).jpg battery box 008 (2).jpg battery box 009 (2).jpg
  12. Dick Stevens
    Dick Stevens
    Hope that works out well for you Larry
  13. t-rod
    t-rod
    Looks great, and easy access too.
  14. Blue One
    Blue One
    from Alberta
    I think it's going to be great.
  15. 26 T Ford RPU
    26 T Ford RPU
  16. Will you have a master off/on switch to isolate the battery in a convenient place so that you can isolate the power when the car is parked away for winter etc. ? I have a battery maintenance charger that I use on the T battery but it is a h***le in the fact that I have to remove the seat base to get to the battery.
  17. Blue One
    Blue One
    from Alberta
    I think I will put one somewhere it will be easy to get to. I also plan to wire a plug in lead directly to the battery in a convenient place for a battery tender.
  18. 26 T Ford RPU
    26 T Ford RPU
    I put an isolator switch on the ground lead and have an accessory socket in my seat riser for dash cam/GPS that a charger can be plugged into. JW
  19. Blue One
    Blue One
    from Alberta
    I'm pumped :D. I posted this as a separate thread but thought I should post it here too. :)
    I was cleaning the garage today and getting ready to have Rod Tops do the top for the RPU.
    I rolled it out into the daylight for a photo shoot for the first time ever since I started building it.
    Next will come dis***embly for finishing. :cool:
    Larry
    roadster outside ! 001 (2).jpg roadster outside ! 002 (2).jpg roadster outside ! 003 (2).jpg roadster outside ! 005 (2).jpg roadster outside ! 006 (2).jpg roadster outside ! 007 (2).jpg
  20. AndersF
    AndersF
    The rod looks great in this thread to.:)
  21. Dick Stevens
    Dick Stevens
    Sure does! :cool:
  22. 26 T Ford RPU
    26 T Ford RPU
    Damn fine looking, sits good......mmmmmmmm I like it:D JW
  23. chessterd5
    chessterd5
    from u.s.a.
    Its a very nice truck! I like the proportions.
  24. nitrobrother
    nitrobrother
    Man, when I started reading and glanced at the picture, I was hoping you'd say you were driving around the block for the first time! I then noticed "a few" things missing off the Y-block...hopefully soon! Looking good, Larry!
  25. daddio211
    daddio211
    Daaaaaamn Larry! Lookin' GOOD brother!
  26. t-rod
    t-rod
    So cool! A fine example of a hot rod.
  27. Blue One
    Blue One
    from Alberta
    Thanks guys. Yes, that's the mock-up block and it will stay there for now. Once the top is done and I blow her apart for finishing the new engine and tri-power will finally sit in it's proper place.
    But it is getting closer :)
  28. nitrobrother
    nitrobrother
    Here's some incentive: Shot by master lens-man Tom Davison at yesterday's So-Cal Open House leading up to the LARS. Y-blocks rock!
  29. kidcampbell71
    kidcampbell71
    .... RPU-T-ful truck. My play on beautiful. Such a cool T.
  30. brad2v
    brad2v
    Looks fantastic Larry. You must be very excited.
