Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Beautiful work! You are a pro!
    loudbang and Blue One like this.
  2. Blue One
    Blue One
    from Alberta
    Thanks Tim :)
  3. loudbang
    That's one hell of an endor*****t when MCTIM64 likes your work. :)
    brEad likes this.
  4. Blue One
    Blue One
    from Alberta
    In doing the initial work I found that the 3 stage turbine in my sprayer was not giving me the atomization that I thought it should so, I sourced a 6 stage turbine and will wait till it arrives to spray color. :cool:
    It will work much better :cool:
    So, that means no color spraying for a few weeks however, it's not like I have nothing to do in the meantime. ;)
    The 6 stage turbine motor I am buying is an Ametek 122097-00, and is a huge amount cheaper than buying a 5 stage HVLP turbine unit from the likes of Fuji, or Apollo who are asking around $1400 USD or more for one.
    The turbine motor will cost me less than $300.
    http://www.centralvacuummotor.com/Ametek/122097-00(High&Low).pdf
    Notice that it has the hose attachment fitting already there as it is a turbine unit designed for HVLP spraying of paint, rather than some of the other motors that are repurposed vacuum cleaner turbines.
    In doing this I know I will get proper atomization from my paint gun so that I can flow a nice smooth finish. :cool:
    Meanwhile I can sand everything down to a super fine finish ;) :D
    Larry.
  5. tfeverfred
    tfeverfred
    "a few WEEKS"? If my hair was long enough I'd pull it out. But, it'll be worth it.
  6. crminal
    crminal
    All your hard work is paying off. Your job is looking great!
    mctim64, loudbang and Blue One like this.
  7. loudbang
    Don't go too fine on the sanding, 400-600 grit is probably the lowest I would use. The reason is the paint needs some fine "imperfections" (in the trade known as tooth) in the substrate to grab onto or you MAY have problems down the road with paint adhesion.
    t-rod, whiplash1923T, mctim64 and 2 others like this.
  8. Blue One
    Blue One
    from Alberta
    Yes, 400 is my stopping point.
    t-rod, mctim64 and loudbang like this.
  9. Atwater Mike
    Atwater Mike
    400 is good, from 'someone who did a 600 finish and the paint adhered like a slippery plastic film'... LOL
    400 is the ticket. (excited you're painting it Washington Blue...) also GLAD you're painting the frame and underpinnings the color of the car. Like it should be. :cool:
    The pics of all the components laid out reminds me of my nephew's reaction when he came to my shop and saw my steel '27 roadster laid out like that. (all in primer, frame alongside, firewall, doors, deck lid all laid out)
    He said, "Uncle Mike! That looks just like when I build a model car!"
    I had seen his work with model cars...meticulous, (hell, he had 20/15 vision!!!) but set up just like this.
    Every time I walk into my shop, I see a 'big model diorama'!
    Darn you, Teddy. You've planted a seed. :eek:
    Blue One and brad2v like this.
  10. Blue One
    Blue One
    from Alberta
    So much for minimal prep for the pickup bed :D
    I spent pretty much all day working on it and still not done.
    Getting closer though.
  11. steel rebel
    steel rebel
    The photographer that took this photo said to me it looks like someone took a ballpein SP hammer to the PU bed. I said yeah me to get it that good. He said don't worry I'll put a shadow on it.
    brad2v, brEad, AndersF and 3 others like this.
  12. Blue One
    Blue One
    from Alberta
    Well the saga continues.
    After many hours and days I 'm done with the body.
    Blocked out with 400 and I've fussed and detailed it about as much as I can.
    So it's going to sit off to the side waiting for paint while I finish preparing the other parts.
    The pickup bed is very close to being ready as well.
    Larry :cool:
    brad2v, rjgideon, loudbang and 7 others like this.
  13. rjgideon
    rjgideon
    Larry, just wanted to chime in that I subscribed long ago and kept up with your updates every few months. Lately I've been checking in every day to see how you are doing. Great work, thank you for sharing and taking us on the journey with you.
  14. Blue One
    Blue One
    from Alberta
    Finished the prep on the pickup bed and the doors.
    Prepped the dash and tailgate.
    Also got the grille shell prepped.
    All I have left is to roll the frame out and sand the epoxy primer on the outer rails down to 320.
    It's been a long road since I started body prep :D
    Then once I get the new turbine it will be paint time :cool:
    Larry
    t-rod, brad2v, loudbang and 4 others like this.
  15. Blue One
    Blue One
    from Alberta
    I had almost overlooked the headlights and tailights, so this morning I prepped and shot them with epoxy primer.
    Had a little extra primer in the gun so I shot a second coat on the side panels that go below the box. :cool:
    loudbang, brEad, brad2v and 2 others like this.
  16. Blue One
    Blue One
    from Alberta
    Wasn't going to mention it but what the heck :D
    I had one of those aw **** moments during the prep of the headlights.
    I was cleaning to paint one of my brand new headlights and it flew from my hands being slippery from the wax and grease remover...:oops: bang on the concrete floor and a nice round dent :mad:
    So, I bumped it out and metal worked it and no more dent, just like new....after a couple of hours :D
    Lesson learned, be careful :D
    Larry
  17. Dick Stevens
    Dick Stevens
    **** happens! :eek::(:oops:o_O
  18. Blue One
    Blue One
    from Alberta
    Yes it sure does sometimes.
  19. Blue One
    Blue One
    from Alberta
    That's it, I'm ready for color.
    Have to pick up a few more body shop supplies and wait till my new turbine gets here. In the meantime I'm pretty sure I can find something to do.
    Like remove the nice deep aluminum pan the transmission builder put on my C4.
    As it turns out it's a beautiful pan but hangs down too low :eek:.
    So, I'm going to cut some out of the middle and Tig weld it back together into a stock depth for ground clearance.
    The aluminum transmission pans are nice in that they seal better on the gasket than the stamped steel ones.
    There's always something to do :D :cool:
    t-rod, loudbang, brad2v and 2 others like this.
  20. 26 T Ford RPU
    26 T Ford RPU
    And there always will be !! :D JW
    loudbang, brad2v and Blue One like this.
  21. Rob28
    Rob28
    from Calgary AB
    Great build I have really enjoyed seeing your progress. Looking forward to seeing some colour on it. Where are you getting your Washington Blue from? That's is the colour I'm planning for my roadster and I'm looking for a local source as I'm just south of you in Calgary
    Rob
  22. Blue One
    Blue One
    from Alberta
    Carlson auto body supply. RM Uno Single stage acrylic urethane.
    loudbang and Rob28 like this.
  23. daddio211
    daddio211
    Wow Larry, looks AMAZING! Sorry I haven't been around much lately but just got caught up. Truck is looking fantastic!
  24. K13
    K13
    Carlson's has a location in Calgary close to what I think they are now calling Deerfoot Mall. They are about 2 blocks North of the mall.
    loudbang and brad2v like this.
  25. Blue One
    Blue One
    from Alberta
    Thanks Eric good to see you back at it on yours too :cool:
    daddio211 and loudbang like this.
  26. Blue One
    Blue One
    from Alberta
    Forgot to mention that I just had them reference Ford code M1747 and they had a formula for Uno.
    They can't mix that color in some other paint types or products.
  27. Rob28
    Rob28
    from Calgary AB
    Thanks K13 I never new there was a body shop paint supply store up there. Great for me because I just work a few blocks from that dearfoot mall location. And now I have the code needed for Washington blue from a local supplier
  28. Blue One
    Blue One
    from Alberta
    Well today my new 6 stage Ametek HVLP turbine motor showed up.
    So I spent the day putting it into the sprayer.
    The 6 stage ***embly is taller than the 3 stage so it required some modifications in order to make it work :D
    The 3 stage turbine took it's motor cooling air in through the same filter as the painting air supply (at the rear of the cabinet) even though it is isolated from that supply and exhausts motor cooling air out the louvers on the sides.
    Being taller the 6 stage motor ended up coming through the top of the cabinet :eek::D
    So to ensure it had filtered air and to keep debris out of the motor's cooling fan I picked up a small air filter and made a lid for it.
    I also had to replace the switch as the original switch contained an 8 amp breaker and it was tripping because the new motor draws more amps.
    So a new switch with a higher rating and no breaker solved that.
    I'm impressed.
    This thing is really going to spray paint :cool:
    It puts out :)
    Larry.
    IMG_1017.JPG IMG_1018.JPG IMG_1019.JPG IMG_1020.JPG IMG_1021.JPG IMG_1022.JPG
    daddio211, brEad, The 39 guy and 5 others like this.
  29. Tim_with_a_T
    Tim_with_a_T
    Sweet! Looks great! No chrome air cleaner? No K&N filter? I guess I'll let it p***. Seriously though. You're gonna be the envy of us all with that setup!
    daddio211, loudbang and Blue One like this.
  30. loudbang
    HOT RODDED paint sprayer gotta love it. :)
    Blue One and brEad like this.
