261 chevy six
Discussion in 'The Hokey Ass Message Board' started by rajcam79, Nov 10, 2009.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, the 261 and early Corvette cam had the same specs, but it's nothing to brag about. There are many grinds out there that would be of greater benefit to your engine. Frank McGurk was the one that discovered that these engines like more lift and duration on the exhaust side, and his "Dual Master" camshafts were a**** the best for 235/261 performance.
  2. Truckedup
    Truckedup
    I've built a coupla of 261's.One had a 848 head,mild Howard M4F cam,Fenton headers and dual carbs,later a Holley 390 four barrel.They run well for a vintage pedestrian engine if you ***emble it carefully and pay attention to piston deck height .Rev freely to about 4500,maybe 180 hp.Certainly as powerful as Flathead V-8's in the same state of tune.but like the Flattie,it's a somewhat expensive HP.
    Myself and other have noticed that a moderately built 235-261's get better fuel mileage that a stock engine.
  3. rajcam79
    rajcam79
    from S.E. MI
    Thank you everyone for the help, and info !!!
  4. rajcam79
    rajcam79
    from S.E. MI
    What oil do you guys use in your sixes ? I have been using Shell Rotella straight 30. Does this oil have the correct ZDDP (zinc) properties?
  5. uglydog56
    uglydog56
    I also run Rotella T. Use the 15-40 diesel oil to get the zinc you're looking for.
  6. rajcam79
    rajcam79
    from S.E. MI
    Thank you ! I will use it next oil change. How much different is it from the straight 30 weigth?
