263 just wont start
Discussion in 'The Hokey Ass Message Board' started by BBobb, Aug 17, 2007.
  1. BBobb
    BBobb
    I got a buick 263 straight eight. A week ago it was running like a top yesterday as I was driving her and she acted like she was out of gas, but she wasnt. Brought her back to the house and put in new points, plugs, cap, rotor, wires, and condensers. I gapped out my plugs and set my points according to the factory specs and she still wont start. I am getting plenty of gas to the carb Im getting a week spark at number one plug. up front thanks for any help I can get because she just wont start.
  2. BtDt
    BtDt
    junk in the carb? wet plugs? color of the spark?
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Check your plugs as mentioned.. if dry...Add some gas by hand and see if it'll start.
    If not go to your distributor for evaluation...and check condenser!!!
  4. BtDt
    BtDt
    yeah was going to say condensor too but he said re replaced it..but they do go bad and if they do the spark ****s..just went thru that on a 6 cyl. here at work last week
  5. BtDt
    BtDt
    really should have a crisp blue spark
  6. sounds like the only electrical part you did not replace was the coil
  7. BtDt
    BtDt
    oohhhh hes good! yeah coil..do it do it
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Checking the coil's a good idea, but two more questions: Is it still six volt, and how old is the gas? Stale gas and slow cranking aren't a good combination.
  9. BBobb
    BBobb
    clean carb dry plugs yellow spark
  10. BBobb
    BBobb
    yes i did replace coil also thanks
  11. BBobb
    BBobb
    yes it is still 6-v and i cleaned out gas tank and has new gas
  12. BBobb
    BBobb
    if i rotate the plug wires out of sequence shoud i not get a backfire
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    For the ten cents it would cost, I'd replace the small wire from the coil to the distributor. Cracked insulation on that wire drove one of my friends nuts one time. It was shorting to the distributor housing and the car wouldn't start.
  14. deucemanab
    deucemanab
    Try Some Starter Fluid.this Wont Solve The Problem But
    If It Starts You Can Tell Better Where The Problem Is.
  15. 302GMC
    302GMC
    from Idaho
    If you can't think of anything else to change, get a compression gauge & a test light ... do a little checking instead of changing.
