264 Nailhead Lifter Problem
Discussion in 'The Hokey Ass Message Board' started by HarryT, Jul 18, 2010.
  1. HarryT
    HarryT
    Yesterday, while returning from the Junkyard Jamboree, the '55 264 nailhead engine in my 34 ford pickup started to make quite a loud noise which I believe to be a single lifter. The noise was loudest at highway speed (with oil pressure at 28-30 psi) and would subside as speed decreased. It would completly go away at idle. Since the noise is not present at idle I can't tell exactly where its coming from. When I rev the engine at idle everything sounds normal. The engine only has 300-400 miles on a fresh rebuild which included new lifters. I read where many lifters are made off shore now days and that there have been quit a number of problems with them. Has anyone experenced similar problems or have ideas on the cause. Also, is there a way to determine which lifter may be the problem? Thanks in advance for any help.
    HarryT
  2. Brad54
    Brad54
    from Atl Ga
    What kind of trans do you have?
    I developed a loud ticking noise in my '54 Special, and it only happened at highway speeds/under load.
    Turned out the diaphram on the rebuilt clutch disc had come apart, and a piece inside the trans had also broken. (factory 5-bolt cover trans).
    It sounded a lot like a lifter tick.
    -Brad
  3. HarryT
    HarryT
    Brad54,
    It has a TH350 trans.
    HarryT
