27 mod update
Discussion in 'The Hokey Ass Message Board' started by NortonG, May 22, 2008.
  1. NortonG
    NortonG
    They're pretty tall already.
    Norton
  2. swade41
    swade41
    from Buffalo,NY
    What's this, an update on this cool machine ?
  3. NortonG
    NortonG
    Getting some stuff done on it, finally!
    Cut the front crossmember out of it earlier today.
    I'll take some pictures this weekend.
    Norton
  4. THE SPEED ADDICT
    THE SPEED ADDICT
    Looking good, Norton!
    Hook up the dam wiring and steering and put'er on the road! Don't worry about stopping because when your burning rubber, ya don't need brakes!:eek:
  5. NortonG
    NortonG
    Update!
    New crossmember is in.
    Time to build a floor.
    Not sure how much to channel it.
  6. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    That thing is *****in'.Love the look and the frame.:cool:I know someone made the comment earlier in the thread that it looked heavy but I'm thinking of doing something along that line.I'll soon be starting on my first rod('27 mod or rpu)and I bought a perimeter "A" frame unwelded from Total Performance.Yeah,they're a little expensive:eek: but I picked it up at their Bunnell,Fl location so I didn't have to pay shipping.Since it's still a pile of sticks I guess design options are wide open.I'll probably go a little wider in the back so I can use my "A" rear crossmember.Keep the pix coming.
    b
  7. WelderSeries
    WelderSeries
    Alliance Vendor
  8. scottybaccus
    scottybaccus
    don't channel it. It just looks right.
  9. NortonG
    NortonG
    Pretty sure it's going to look like this.
    WAY more pan clearance now.
    Still lots of brackets, gussets ect to put on.
    Thanks to Welders Series for making a great front crossmember.
  10. swade41
    swade41
    from Buffalo,NY
    Looking good, whatever you do don't put the cowl lower than the shell, you'll never here the end of it...lol
  11. NortonG
    NortonG
    haha, I think it looks pretty good where it is.
  12. sko_ford
    sko_ford
    1 quick question. will the cross member want to pull open with it mounted just from the back like that?
    and another vote for little to no channel
  13. NortonG
    NortonG
  14. Flying Tiger
    Flying Tiger
    from Japan
    Great work! Looks nice! Keep us updated on your progress on it!
  15. WelderSeries
    WelderSeries
    Alliance Vendor
    I was looking at that too... I probably would have just made a notch in the frame rail and set the crossmember up in the notch rather than ****ing it up against the back side. If you weren't left with enough rail after you took the other crossmember off, then you're probably best making a gusset, like you said. What about continuing the outside of the frame rail to the front edge of the crossmember? Is there enough room for spring clearance at the very outside?
    I like the first picture too - nice line from the cowl to the shell, and I really like the wishbone placement at the cowl line and door line!
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Looking great Nort
    Hope to see and your pop soon.
  17. tbraginton
    tbraginton
    from Nevada
    Make sure and keep us up to date on this one I'll be excited to see more as it comes along.
  18. NortonG
    NortonG
    We cut the old crossmember out with plans for putting the new one in between the rails but, we really didn't like the way Grant had added extra length to the rails.
    When Skunk had first started the frame, he tapered the rails and they looked very good.
    Grant added some tubing to the ends of the rails and didn't make it the same height as the tubing it was welded to and it looked like ***.
    So we cut it off.
    D.W. I like the idea of continuing the outside of the rail.
    I'll do some measuring and let you know if that'll work.
    Thanks for the kind words fellas.
  19. dakotajayne
    dakotajayne
    from 3c1
    I noticed a gas tank on your wall, are you using that? Where are they made? Looks like a great project! Im working on a similar version.
  20. very nice I think I should of went that way with my frame
  21. looking good. i cant wait to see this thing ripping around
  22. NortonG
    NortonG
    dakotajayne, I am using it. It'll be hanging off the back of my car.
    I know that The HotRod Company sells them. They're an alliance vendor as well. 5% off.
  23. NortonG
    NortonG
    Comments and opinions are appreciated.
    Norton
  24. Jeem
    Jeem
    Alliance Vendor
    I really like the stance and proportions, the rubber rake, everything looks good to me. Don't get too low in back and keep the channel to a minimum. Me likey!
  25. tjm73
    tjm73
    I see in one of the pics you are running 500-15's up front. It also look slike you are running maybe 820-15's on the back? What size wheels? What are they off from?
    Man this car is sweet!
  26. tbraginton
    tbraginton
    from Nevada
    What are your frame dimensions? I'm planning a very similar car myself and I Love the look youve got going...
  27. NortonG
    NortonG
    tjm73, You're spot on with the tire sizes. The wheels are 15x5 and 15x7. They are from Wheel Vintiques.
    tbraginton, I'll take some measurements for you.
    Thanks guys!
  28. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Any progress over the weekend?
  29. NortonG
    NortonG
    Not much progress to report...
    I'll be hitting this thing hard next week!
    Need to get the front of the frame done and the floor structure in the body.
  30. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Any progress or updates?You're killin' me here.Gotta see how this one turns out.*****in' so far.
