Technical 27 roadster on 41-48 chassis
Discussion in 'Traditional Hot Rods' started by falconsprint63, May 19, 2018.
  1. falconsprint63
    falconsprint63
    from Mayberry
    ***le says it all. I know it's been done, i remember seeing pics somewhere along the way.
    I Have a bead in a good running 41, with a trash body. Been thinking about a flathead powered 27 roadster for a while. I know the 41 could be a donor to a A or other ch***is but seems like a ton of extra work if i can run the 41 ch***is
    Anybody got pics or build details.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  2. thirtytwo
    thirtytwo
    Gut everything off the 41 ch***is and put them on a set of 650.00 32 rails is the easiest best way to make that happen
  3. falconsprint63
    falconsprint63
    from Mayberry
    That is an option under consideration. Just doing my advanced research. The 41 has the benefit of a clear ***le which is a pain to get here in nc. ***le goes with the ch***is regardless of what's on it.
  4. Model A Gomez
    Model A Gomez
    A 41 ch***is is way too big and heavy for a T roadster body, you can do it but won't look right. A Model A or 32 ch***is is a lot better choice. Don't know what ***le requirements your state has but would find out before I started.
  5. 46stude
    46stude
    https://www.jalopyjournal.com/forum/threads/the-free-t.1104506/
    You might get some ideas from that thread.
    falconsprint63 likes this.
  6. Tim
    Tim
    from KCMO
    What he said ^
  7. studebakerjoe
    studebakerjoe
    Falconsprint check out the babushka t build. Ed lloyd used a modified 47 mercury frame. Came out real nice.
