Technical 27 T Front Shock Question
Discussion in 'Traditional Hot Rods' started by stowe, Feb 27, 2017.
  1. stowe
    stowe
    Hello I am in the process of building my 27 roadster on a 31 frame and dropped axle. Ride height is 14 inches. I am using Brookville frame mount headlight/shock mounts,and speedway forged lower mounts. I center to center measurement of 14 1/2 inches between lower and upper shock mounts. I am trying to figure out what the proper size shocks would be, speedway has a a shock that is 10.63 inches compressed and 16.38 extended. I was wondering if this shock would work also If any one has used a more available shock . I have 5/8 lower mounts . Thanks
  2. Jalopy Joker
    Jalopy Joker
  3. brokenspoke
    brokenspoke
    Do a search "Monroe Shocks dimensions re-arranged"
  4. stowe
    stowe
    Thanks I looked at both Monroe and Gabriel shocks
  5. stowe
    stowe
    I found a shock that met my requirements It is a dual tube small body shock . Issue I have now is that the shock tube body hits the out side of my brookville shock headlight mount. I could machine away some material on the mount or try and find a mono tube shock . I found one on speedway but it is a gas charged shock any ideas?
