Projects 27 T on A rails
Discussion in 'The Hokey Ass Message Board' started by Equipped28, Dec 26, 2013.
  1. Hitchhiker
    Hitchhiker
    The hood gives it a whole new look!
    volvobrynk likes this.
  2. 26 T Ford RPU
    26 T Ford RPU
    That looks real cool and ties the whole car together well. JW
  3. gwhite
    gwhite
    SUPER MODERATOR
    Excellent, thanks for the info...what front crossmember are you using? I had measured out 4 1/2" or so on mine (May 1930 ch***is). Might need to go back and re-measure; yours looks spot on!
  4. Where did you get your windscreen frame from, please? Liking everything about this little car and you are making me get back interest in mine. Thanks for the posts.
  5. Equipped28
    Equipped28
    Mine is stock 30/1 front cross member too. There maybe a difference as the body is gl***?
  6. Equipped28
    Equipped28
    It's an old repro hallock for a 28/9 model a that I sectioned and had my friend weld back together.
  7. Equipped28
    Equipped28
    i feel like i'm going backwards but hopefully i aint. last time its blown apart i hope!!
  8. Hitchhiker
    Hitchhiker
    Side profile is ****ing killer!
  9. Frankensteiner1
    Frankensteiner1
    I dig this build a lot!
  10. 26 T Ford RPU
    26 T Ford RPU
    Love this build and your attention to detail. Do you have any detailed pics of how your back end is mounted? JW
  11. Equipped28
    Equipped28
    It's just a 39 rear end with the bells flipped and a T spring out front. And then the frame shortened to bring the wheel base back to stock model at 104". I'm tempted to step the rear the depth of the rail. Not sure yet.
  12. bct
    bct
    I like it as is.
  13. Equipped28
    Equipped28
    Gonna run different tyres, 600 front & 700 rear, 5.50 & 600 mocking up at the moment. It's looks a lot lower than it is.
  14. 26 T Ford RPU
    26 T Ford RPU
    It has the right stance now and the new tire combo will lift it roughly the same at both ends. Try it first. Oh, and im really digging your car!!!!!! JW :D
  15. Leon Sandcastle
    Leon Sandcastle
  16. Equipped28
    Equipped28
    I've been hammering away on it for the past week or so. to get the T looking finished for a show my girlfriend is doing with her work, Promoting hydraulic hoses.
    brEad, volvobrynk and 26 T Ford RPU like this.
  17. 26 T Ford RPU
    26 T Ford RPU
    With the change in color it looks a different car, its gone from looking real cool to fantastic !!! JW :D
  18. Equipped28
    Equipped28
    And that's just the primer!
  19. OFT
    OFT
    Sharp looking in primer! What's color to be?
    Earl
  20. 26 T Ford RPU
    26 T Ford RPU
    I was surprised its in primer as it looks like vintage off white satin type of color. COOL!! JW :D
  21. Equipped28
    Equipped28
    LA armoury show 1948.. Or maybe not!
    volvobrynk, chaddilac and Hitchhiker like this.
  22. 26 T Ford RPU
    26 T Ford RPU
    That's just too cool !! JW :D
  23. seatex
    seatex
    Really looking good! I like everything about it. I really dig the hallock style windscreen with the rear deck, it flows, man!
  24. Equipped28
    Equipped28
    on the home stretch now, an idea i've been toying with for a while but now i've put them on i think splash apron's are a keeper.
  25. jmiller1918
    jmiller1918
    from Tulsa, OK
    I like the splash aprons! Cool looking roadster.
  26. 26 T Ford RPU
    26 T Ford RPU
    Loved the car from the start, but not sure on the aprons/valances. JW
  27. volvobrynk
    volvobrynk
    from Denmark
    Thats a nice rod, I would not rind those aprons. I've seen rods that ran with just aprons, but not all can pull it off.
    Maybe you should consider making a roll pan, just make it in a shop brake.
    Take along piece of sheet metal, as long as your brake, and bend it 90*, and at then the depth of the frame you make a slight bend, move it 1/2 inch another slight bend and keep doing it till you got the shape of a J, then try putting it between the body and frame and step back an look if it's more the look you would go for.
    Then you can eighter make a 4-5 and weld them together, or have a big firm bend one that fits from axel to axel.
    That would look better IMHO.
  28. Equipped28
    Equipped28
    Not touched it for a while and wasn't happy with the ch***is work i had done i decided to take it to work and blow it apart & finish it once and for all. i wanted to bring the back end down so the tyre fills the arch so with a 2 1/2" kick up and mocked with 700 tyres out back and 600's on the front and i think its pretty spot on!
  29. 26 T Ford RPU
    26 T Ford RPU
    That's looking fantastic and some interesting things in the background. JW:D
  30. Equipped28
    Equipped28
