Projects 27 T project
Discussion in 'The Hokey Ass Message Board' started by alteredimage, Aug 31, 2008.
  1. alteredimage
    alteredimage
    A front rails Z'd 3" at the front, 390 FE engine with a T5 trans. Got the front end from Riley's awsome customer service and awsome parts!
    Everything is just in for mock up right now even the X member. It will be smoothed and filled with lightning holes.
  2. blackout
    blackout
    Man youve got a fine start there. Nice frame mods. 390 and 5 gears will go like hell. You going to chop it?
  3. chaddilac
    chaddilac
    Welcome to the T Coupe club!
  4. alteredimage
    alteredimage
    Not sure on the chop yet going to see what it looks like on the ground first. Got a Franklin Q/C for the rear also.
  5. MyBootsOnFire
    MyBootsOnFire
    I love FE motors. How hard was it to hook up the T5 to the 390? I would love to run that combo.
  6. hrm2k
    hrm2k
    Welcome to the T owners group...it looks good
  7. mink
    mink
    from CT
    are you running that camaro t-5 tilted?or you going to correct that?? mines sets up like ur s is now
  8. fiftyv8
    fiftyv8
    from CO & WA
    Nice work and keep those model T coupes comin.
    Post more pic's when you have them.
  9. blackout
    blackout
    Shifter looks straight up. Chevy Camaro bellhousing has the 15' tilt. Fords are straight up.
  10. I'm leaning toward a 27 roadster. Pardon my TOTAL ignorance, but is that a 27 frame :eek:? I am considering a 32 frame, and strength is one of the reasons. However, a channeled 27 roadster is a CLASSIC, and was my "since-I-was-a-kid" all time favorite. Mistakes are expensive, and I don't want to make any...
  11. blackout
    blackout
    This is a modified A frame. A 27 roadster on top of deuce rails is one of the all time classic combinations, there is a recent thread of a HAMBER who just got one from the 60's on the road again. My 2 bits, if you are going to channel the roadster, use an A frame, or a custom frame, like Riley Auto, a HAMB vendor. Deuce frames are very pretty exposed and more expensive.
  12. blackout
    blackout
    I will also say that if you decide to channel your roadster over deuce rails, you will have a stronger frame, and you will have the great sweep, wheelbase help. Roadster channeled over deuce rails, pretty fine.
  13. blackout
    blackout
    I found a reference for you. May 1962 Rod & Custom, Rod Test on Gary Heliker's 26 roadster channeled over deuce rails. Car is 100% perfect even today.
  14. alteredimage
    alteredimage
    The front rails are Model A. The rest is 2x3 box tubing the X member is 2x3 cut in half then notched to get the bends. I didn't want to do the traditional cross style crossmembers just to be difrent I guess. The T5 is a Ford unit the shifter is titled in that pick because the engine is still hanging from the hoist. Building the front cover into mounts for the engine. They sell a conversion bellhousing for FE to T-5 and Rileys even has an adapter plate from FE bellhousing to T5.
    Josh
  15. boo
    boo
    from stuart,fl.
    COOL..have all the parts for my 27 cp. A front rails 2x3 tube fr/wall back,chpd. chan.streched ,21 stud eng, 39 linc gear box, columbia od w/4.11 gr. body is cherry, almost to good to channel, need more time.....
  16. alteredimage
    alteredimage
    This body has 0 rot at the bottom the sub rails were mint. But as cool as they are unchanneled I wanted a channeled T so out came the grinder.
