27 T sedan Frame
Discussion in 'The Hokey Ass Message Board' started by hotrodwelder, Oct 11, 2010.
  1. hotrodwelder
    hotrodwelder
    Ok, I have aquired a '27 T 2dr sedan, what frame looks good under these? A set of A rails or '32 rails? Lemme see some pics..
  2. Either on. If you use an "A" frame, you will probably channel the body the width of the frame, and loose some head room. Might be a problem if you chop it. If you use the 32 frame, set the body on top of it, and you could drop the floor down into the frame, giving you more head room. Dean
