5 days off for the holiday and trying to get 1 of the projects movable. Plans are to drop a flat head ford engine in. Rear is 8 inch. So far with engine and all about 1500 invested Sent from my SM-S367VL using The H.A.M.B. mobile app
Wow, looking good so far. And quite a bit there for the money spent. Looking forward to seeing your progress.
Is it supposed to go behind the axle??? That is how it was installed when I got the axle??? Sent from my SM-S367VL using The H.A.M.B. mobile app
Yes, just remove spring hangers and turn axle around. (you could say axle's going backwards now...Just turn it around) Also just consider a Model A frame. Some kickup at rear O.K., just a little more 'conservative' than the 'high step'? 4"-6" is usual.
Is there a way to determine what year my front axle ,spindles are? Sent from my SM-S367VL using The H.A.M.B. mobile app
I ran into a little issue today. The rotors that came with the axle, I was told was g.m. a 68 Camaro seal fits. I believe I need a spacer to go from ford spindles to g.m. bearings. Does somebody make and sell just the spacers for such a thing? Sent from my SM-S367VL using The H.A.M.B. mobile app
Thats a model A axle. Spindles look like theyre 40 Ford type. If I look close at the picture they almost look aftermarket specifically how chunky the one at the p***enger side looks on top but might just be the picture Edit: Woops! After seeing the last pictures posted they definitely arent 40 spindles. I coulda swore they were round in the first pics. Sorry.
Usually, when installing Chevy hubs on Ford spindles, you need to machine a little on the spindles for Chevy outter bearings. Simple though. r Every once in a while, life gets a little more surreal.
Definately NOT 40 spindles. Those sure did look round in the first pictures. As posted they're the late ones.
