Projects 27 Tudor build
Discussion in 'Traditional Hot Rods' started by TrueBlue23, Oct 28, 2022.
  1. TrueBlue23
    TrueBlue23
    Hey folks,,picking up a 1924 Tudor that im itching to tear into. Super clean unmolested body and all. Been spending the last week researching and gathering ideas.
    Going back and forth on the frame I wanna use. originally wanted to use a model A style frame with the horns and axel under. But now leaning towards a 27 T frame from Speedway,,trying to find some measurements comparing the 23-25 and the 26-27. I know there are some differences, but not sure exactly what they are. Any T heads wanna shine some light on it for me? Thanks in advance for any input.
    Okie Pete, Just Gary and don colaps like this.
  2. Primered Forever
    Primered Forever
    from Joplin,MO
    I’m not a T guy but it looks like a 26 or 27 to me.
    flatheadpete likes this.
  3. alchemy
    alchemy
    Yeah, that's a 26-27. And those are 28-29 A front fenders. It might already be on an A frame.
  4. Yep, A frame. I can see one of the holes for the Model A transmission mounts
  5. TrueBlue23
    TrueBlue23
    Hmm weird. The guy I’m buying from is a pretty knowledgeable old hot rodder. He says it’s a 24
  6. alchemy
    alchemy
    More knowledgeable than us?!
    vtx1800, Budget36, Packrat and 2 others like this.
  7. No it's a 26 - 27. The firewall and flare at the bottom of the A pillar where it meets the cowl confirm this, the new for 1928 Model A kept that design feature. I'm sure he has forgotten more than I currently know but he is mistaken on this one.
    Packrat likes this.
  8. TrueBlue23
    TrueBlue23
    Got it. I see you what you’re talking about now. Thank you guys for the insight
  9. HOTRODPRIMER
    HOTRODPRIMER
    1924 T sedan
    1926/27 T sedan
    I'm not a Model T guy and I see very little difference in the two bodies, I have owned a few Model A's and I believe the front fenders are 28/29. HRP
  10. Primered Forever
    Primered Forever
    from Joplin,MO
    Firewall was a dead giveaway for me.
    TrueBlue23 likes this.
  11. micshotrodgarage
    micshotrodgarage
    from colorado
    My chim-in 26-27 Better off with the Improved years, Alot less wood and more Henry steel! As far as T frames go the over all length is the same but cross members are different in how the body mounts. Your T is super cool project; A great start. If it has the A frame under it I would stick with that. I am building three 26-27 Roadsters lakester| trad, trog cars. Looking forward to following this tread!! I'm in!!
  12. Rickybop
    Rickybop
    The owner may have said it's a '24 because that's how it's ***led? So maybe verify that... sooner than later. Good luck with everything.
    Packrat and TrueBlue23 like this.
  13. TrueBlue23
    TrueBlue23
    Yea it’s ***led as a 24. Picked it up today. Not sure if it was a case of someone purchasing a ***le for a car without one or not. Not a huge deal to me what it’s ***led as. But after seeing the car in person it sold me even more on it. Crazy clean. Think I’ve decided on a 27 T frame..I like the A’s with the horns, but something about that dropped axel out front that I just love. Maybe a spring over application and raised perch up front 2E9E143B-1493-4BF0-82F2-E6CA1D8F19AD.jpeg 7CA94BFA-0138-4D51-9582-6226EF73C3FC.jpeg AFC0D351-7FFF-4833-B1CE-8B974FA3A737.jpeg
    Just Gary and Big Al like this.
  14. panhead_pete
    panhead_pete
    Looks nice. What happened to the rest of it? Was that a LaSelle ****** on the running boards? Sure looks like it might have been a hotrod in its past, engine swap, steering, even hydraulic brakes? Please tell me you are bringing all that home too.
  15. TrueBlue23
    TrueBlue23
    I got the body, fenders, running boards, and all the body parts. He’s using the frame and suspension on another project. I’ll prob get rid of the fenders if I find someone wanting them
    panhead_pete and ccain like this.
  16. TrueBlue23
    TrueBlue23
    Spent the last couple weeks gathering a few bigger parts..got the body home, found a 9 inch, and picked up a 331 Caddy to go in it. Picked the frame up last week as well. So ready to get mocking up
    1E684086-A7F9-40D5-B114-A0B556C37CF3.jpeg A21C8C6C-1726-4D49-BD30-78624AD20750.jpeg A2A54BA0-BA43-4492-A0FF-9DE94588D479.jpeg 1FC54CB9-086C-41BF-AF29-596D1C68AEE5.jpeg B381D4C5-6DAE-48A0-B614-887F5036A068.jpeg A548AC5D-415B-4798-90EA-3C611233A6A7.png
    Just Gary likes this.
  17. TrueBlue23
    TrueBlue23
    Also got a set of Ford rear radius rods. Trying to figure out the best way to mount them? Connected at the center below the driveshaft/****** support. Or cut the ends and add tie rods and mount to under frame rails? Any suggestions?
    A6F76ECF-9838-44A4-AD0A-1717341550D4.jpeg 9AE69533-D5AA-4866-B98B-5A0A9927E860.jpeg 8601EF78-3736-422C-B5ED-74326809E2B4.jpeg
  18. alchemy
    alchemy
    Never split rear radius rods or ladder bars all the way out to the frame rails. A very poor design and will break parts. Keep the front of the bars as close together as possible, just as Henry did.
  19. caprockfabshop
    caprockfabshop
    Agreed, there have been multiple threads that show that the closer to the centerline of the car and further forward the ladder bars go, the more stable and functional the rear suspension is. 4 Links are designed to go parallel, not radius rods and a transverse leaf.
    ~Peter
    Just Gary and TrueBlue23 like this.
  20. TrueBlue23
    TrueBlue23
    What about a torque arm? Is it needed? It’s not going to be a high hp motor. Running a spring behind the axel if that makes a difference. Thanks for the input!
  21. caprockfabshop
    caprockfabshop
    Here's mine, it has ladder bars, but the radius rods you have work on the same principles:
    As the rear end "loads up" under acceleration, the radius rods/ladder bars prevent the pinion yoke from dipping. Meanwhile, the transverse leaf prevents excessive side to side sway under cornering. You'll still get a little movement in the spring shackles, but it's minimal.
    ~Peter
  22. Those rods are not designed to handle any kind of twisting load, their only job was to keep the rear axles square to the torque tube, which you no longer have. Before I knew this, I did the same thing you plan to do and they snapped at the welds. A mostly stock flathead was enough to break them on a 2060 pound car.
  23. caprockfabshop
    caprockfabshop
  24. TrueBlue23
    TrueBlue23
  25. TrueBlue23
    TrueBlue23
    Started channeling today.
    083C4A6C-6415-4516-9435-4054E12C49F7.jpeg 5AC9DEF5-F57B-49A4-BB64-7A159939382A.jpeg 00BF8A95-44A0-4762-96A7-D948D9C66EE5.jpeg 29B30862-0BF3-455A-847E-E561DB3BBE3C.jpeg
    OpenThrottle likes this.
