Hot Rods 27 with a 25 turtle deck. IT'S A HOT ROD
Discussion in 'The Hokey Ass Message Board' started by Frames, Feb 23, 2016.
  1. Frames
    Frames
    27 tub. V-8 60 tube axle. Mono leaf spring. 42-48 dropped bones. Wilwood GM calipers. Stock Car Products hats and rotors. 6 pin sprint car knock off hubs. Halibrand magnesium wheels. Flathead engine. Stamped steel bell housing with low throw out arm for floor clearance. S 10 five speed trans. Car water pumps. No need to use truck pumps and build the tall stand. Spread body 2" at the bottom for foot room. Fabricated rear frame kick up to fit the body. Rodsville quickchange with cover of unknown manufacture. TRACK ROADSTER-street 015.JPG TRACK ROADSTER-street 010.JPG TRACK ROADSTER-street 011.JPG TRACK ROADSTER-street 012.JPG TRACK ROADSTER-street 013.JPG TRACK ROADSTER-street 014.JPG TRACK ROADSTER-street 015.JPG TRACK ROADSTER-street 016.JPG TRACK ROADSTER-street 017.JPG TRACK ROADSTER-street 018.JPG TRACK ROADSTER-street 019.JPG TRACK ROADSTER-street 020.JPG
    Squablow, ls1yj, biggeorge and 8 others like this.
  2. All the cool parts, I'm keen to watch how this goes.
  3. willymakeit
    willymakeit
    Keep posting. Have always liked these.
  4. I always enjoy your builds, watching.
    kidcampbell71 likes this.
  5. Jalopy Joker
    Jalopy Joker
    Wow - ya doing good
  6. alchemy
    alchemy
    What's the little tag on the rear cover say? If it's a number like 3602 it's a Pat Warren cover.
    It's funny that you widened your body, cause I'm building a '26 with similar parts and I narrowed my body 6 inches.
    Atwater Mike likes this.
  7. Frames
    Frames
    finished the engine mounts. mounted the front axle ***embly. installed the Armstrong shocks. mounted the rear axle ***embly. 27 T--SPRINT HEADERS 011.JPG 27 T--SPRINT HEADERS 012.JPG 27 T--SPRINT HEADERS 013.JPG 27 T--SPRINT HEADERS 014.JPG
    Hnstray, biggeorge, T-roaster and 4 others like this.
  8. AHotRod
    AHotRod
    I like it and will follow along ....
  9. Frames
    Frames
    I spent the last 3 days doing the cowl steering. I'm using cowl steer because I need the space up front for a larger radiator to cool the flathead. The 52 Willys steering box was a gift from Leon Brown. I really like it because of the way it mounts. Makeing room for my feet. I used to do circle track steerings [Mopar] back in the 60's with a 2" tubular extension and a 265 SBC connecting rod for the outer support. On this hot rod I wanted it to look more proffessonal. I made a very short adaptor and then I used a Pittman arm shaft from a Chevy box. I had purchased an aftermarket arm a while back at a swap meet. I made a mandrel to turn down the Willys Pittman arm to accept the tubular extension. The Chevy shaft will be shotened after I install the body. The vertical frame will be braced to the door jambs. The drag link is perfectly horizntal. I have 2 1/2 turns lock to lock but I think I will speed it up some by shortening the steering arm. CAD---32--Willys 52 004.JPG CAD---32--Willys 52 005.JPG CAD---32--Willys 52 006.JPG CAD---32--Willys 52 018.JPG
  10. Offset
    Offset
    from Canada
    Looking forward to seeing this one come together.
  11. AHotRod
    AHotRod
    Excellent engineering
  12. Mr48chev
    This is going to be interesting I can see now.
    Is that a Jeep CJ steering box? They pull those out around here an put Saginaw boxes in when they redo the Jeeps for serous four wheeling in the mountains.
  13. wicarnut
    wicarnut
  14. dechrome
    dechrome
    I love your build. V8 60 front axle can't be beat. Real mags with knockoffs OK.
    Are you going to put a rear deck on it? My similar concept.
    dechrome
    biggeorge likes this.
  15. Frames
    Frames
    yes I plan to build an aluminum trun Track roadster 5.jpg Track roadster 5.jpg Track roadster 11.jpg k just like my circle track roadster # 1.
  16. dechrome
    dechrome
    Dynomite!!!!
    deChrome
  17. Frames
    Frames
    Found a Woodward NASCAR steering column [ neat piece] with a Rebco quick release steering hub at the swap meet 4-9-16. Fitted it to the car 4-10-16. Had to make an adapter sleeve. FRANKLAND w LOCKER. OFFY INTAKES 027.JPG
  18. big duece
    big duece
    from kansas
    Very nice, Dennis.
  19. Frames
    Frames
    Did the plywood floor. Widening the body 2" at the bottom and doing the trans cover 1/16" away from the bell housing gave me just enough room for 3 pedals. Will install floor with SEM structual adhesive. Did the brake and clutch. Did the accelerator useing a Nascar setup. Another neat piece found at the swap meet. Mounted a very small alternator. Got lucky there. 1/2" thick slingshot mount just the right thickness for perfect belt alignment. Had to rework the Speedway Motors pulley. Painted the Halibrand wheels. Camera flash made the rear wheel look a little light. TRACK ROADSTER PROGRESS # 3 001.JPG TRACK ROADSTER PROGRESS # 3 002.JPG TRACK ROADSTER PROGRESS # 3 003.JPG TRACK ROADSTER PROGRESS # 3 004.JPG TRACK ROADSTER PROGRESS # 3 005.JPG TRACK ROADSTER PROGRESS # 3 006.JPG TRACK ROADSTER PROGRESS # 3 007.JPG TRACK ROADSTER PROGRESS # 3 008.JPG
    Hnstray, biggeorge, T-roaster and 2 others like this.
  20. falcongeorge
    falcongeorge
    from BC
    Slicker than goose ****. Always love to watch your builds...Really like the rear spring hangers.
  21. DDDenny
    @Frames
    When you can, how about some closeups of that finished throttle setup.
    I see the Clecos on the firewall, are you mechanically fastening it or bonding it?
    Another question, what paint did you use on the Hal's?
  22. 38Chevy454
    38Chevy454
    Nice work, nice parts, and nice progress!
  23. AHotRod
    AHotRod
    I'm Loving it !
  24. Frames
    Frames
    Did the blue print for the custom radiator, 5-15-16. Built 2 seats today. One piece. 4 small bends for the sides. [ on my big early 1900 brake ] The bottom bend I did with one foot standing on it and pulling up. Did the final bending on the shift lever. seat--573--brakes--27 006.JPG seat--573--brakes--27 007.JPG seat--573--brakes--27 008.JPG seat--573--brakes--27 011.JPG seat--573--brakes--27 012.JPG seat--573--brakes--27 013.JPG
  25. big duece
    big duece
    from kansas
    Dennis, what heads are we looking at in the previous post? Evans? the no thermostat is throwing me.
  26. Frames
    Frames
    Evans marine 59A heads. Will be useing on the 8BA block. will also be useing a 59A Schooler camshaft. i think RAM-FAN-V-COVERS 013.JPG RAM-FAN-V-COVERS 014.JPG RAM-FAN-V-COVERS 015.JPG it will be a clean looking engine. spent a lot of time making an adaptor for a modern fan, but now i realize it sets too high.
    grumpy32 likes this.
  27. Roadsir
    Roadsir
    Great build, Nice mix of race parts and hot rod parts.
    What are you targeting for a wheelbase?
  28. Frames
    Frames
    To me the car looks quite long right now, but the wheelbase is only 108".
  29. Frames
    Frames
    Did the driveshaft tunnel and transmission cover this week. I have made trans covers one piece in the past. Never again. I taped my 32 style gauge thing in place to see how it looks. A little big for this narrow dash. Most likely won't use it. FRANKLAND...27...FENTON 007.JPG FRANKLAND...27...FENTON 008.JPG
  30. Frames
    Frames
    Unable to find windshield posts that I liked so I built my own. The 3/4" tube at the bottom drops into the door jam reinforcement [1" X 1 1/2"] DRUMS----WINDSHIELD POSTS 008.JPG DRUMS----WINDSHIELD POSTS 006.JPG DRUMS----WINDSHIELD POSTS 005.JPG DRUMS----WINDSHIELD POSTS 010.JPG DRUMS----WINDSHIELD POSTS 009.JPG and is secured by a bolt near the bottom. The aluminum jig is a little flimsy but masking tape helped do the job. The center spacer is 3/8" X 3/8" bar stock. Had to do 4 p***es [TIG] for the fillet at the base. I guess a metal caulking gun [MIG] would have worked better. I do the prep work for chroming.
    grumpy32, AHotRod and Gofannon like this.
