1952-59 Ford 272 Tuning question
Discussion in 'Off Topic Hot Rods & Customs' started by jeff355, Jun 2, 2012.
  1. jeff355
    jeff355
    Hi guys. Im planning on an engine swap next winter, but for this year after Hamber opinion Im running the stocker. Its all stock 272 3spd with new plugs, points, condensor, cap rotor and wires. The old girl runs good but I have a "popping/backfire" in the exhaust on a quick deceleration. Can I tune this out- or is this a common issue?
    It drives me nuts, and Im still running the stock crossover exhaust. I want to put a performance muffler on- but fear that will make it even worse.
    Any suggestions or ideas ?
  2. danman55
    danman55
    What carb are you running? Certainly sounds carburetor related.
  3. jeff355
    jeff355
    Stock carb. You know, I took the ****py oil bath breather off and the car ran 95% better. Still a little popping, but way better...
  4. Custom_Crestline
    Custom_Crestline
    Are you just talking about the pipes rapping? Thats just kinda how y-blocks sound?
  5. Ole don
    Ole don
    If the car runs better with the oil bath removed, it may have to much oil in it and its restricting air flow. A pop out the exhaust on throttle closing says its a bit lean. The oil bath thing would make it lean. Double check the oil level in the air filter and report back.
  6. jeff355
    jeff355
    Thanks, it does have too much oil in it. Im gonna get a nice open element and put that POS up on the shelf. You guys are great ! It barely even pops now.
