28-29 cowl/tank conversion on a 26-27 t coupe info needed
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Oct 31, 2010.
  1. oldrelics
    oldrelics
    from Calgary
    Anybody here done the conversion of using a 28-29 tank/cowl on a T-coupe? Is the cowl removable from the hinge pillars on the T or does a guy have to get that from the 28-29?
    Thanks
    I found this pic here on another thread..
  2. fiftyv8
    fiftyv8
    from CO & WA
    I dont know for sure, but I'd say there maybe a little work to get them to fit together.
    One trick maybe to use model A pickup hinge pillars.
    The model A has a different bolt up arrangement to that of the T.
    The model T cowl is about 1 inch longer front to back compared to the model A.
    Not sure why you would consider the swap exactly, except to say you would probably gain capacity if using the original gas tank from the model A.
  3. The37Kid
    The37Kid
    Glad to see someone trying to do this! I believe you need the 28-29 Closed Cab Pickup hinge post, then the T doors and body just bolt on. You could fab up an adaptot and put the A tank and cowl on a T but using the a hinge posts is the quicker way around it. Please post photos of the build!:)
  4. tysond
    tysond
  5. oldrelics
    oldrelics
    from Calgary
    I would consider the swap just for the look alone never mind gaining more engine compartment clearance area and the original tank.
  6. DeadFast 33
    DeadFast 33
    from Santa Cruz
    That picture was taken at my house cuz that car use to be mine, I have since sold it. Unfortunately I can't help much as the car looked factory? I was told that possibly it was a late 27? not sure though????
    If your looking to make one of your own it seemed to fit quite easily??? and imo looked quite good!!
    FLiP
  7. from what i can see in the picture it looks like `28-`29 closed cab pickup door posts. that's what i'd look into if i was doing the swap
  8. gimpyshotrods
    gimpyshotrods
    X2. The 28-29 CC Pickup door posts will do the trick.
  9. HuffDaddy
    HuffDaddy
    oldrelics, have you found out any more on connectioning a 28-29 Model A cowl to a 27 Model T Coupe? Since I've seen this thread, I've been thinking about doing the same thing.
  10. oldrelics
    oldrelics
    from Calgary
    I'm pretty sure you need the 28-29 pickup hinge/windshield posts to do it, since most say that they share the doors with the 26-27 T coupe.
  11. 117harv
    117harv
    Anymore info to add to this cool mod?
  12. The37Kid
    The37Kid
    If someone built a 26-27 Coupe on an a chassis I'd like to see how the rear fenders fit. Bob :)
  13. chaddilac
    chaddilac
    I'd just grab a tank and cowl sides and the windshield rail and go from there, everything else looks T coupe to me!!
  14. carmuts
    carmuts
    I remember trying this back in the 80's (when I was 16 or 17) before I had a welder and other things neccessary to accomplish it. I beleive the main problem was the cowl was abit too wide. With the things I have in my shop now I am sure I would get it done. Rod
  15. -Brent-
    -Brent-
    There's a thread on this.
  16. The37Kid
    The37Kid
    Thanks Brent! A few years ago there was the reverse of this 26-27/28-29 swap. A 28-29 Closed Cab pickup with a 26-27 cowl fore sale at the CSRA swap meet. Bob :)
  17. BUMP because this is awesome.
  18. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    i've seen it done one closed cars but never a roadster. i think it would look good as the bead down the 1928-1929 cowl would match the rear quarters on the 1926-1927 roadster.
  19. My Father built this t coupe on an A frame I hauled out of the woods. He used glass A fenders and the rears fit well. ImageUploadedByH.A.M.B.1374208181.479838.jpg
