Hot Rods 28/29 model a coupe assembly
Discussion in 'The Hokey Ass Message Board' started by Jacob1963, Mar 26, 2025.
  1. Jacob1963
    Jacob1963
    from Omaha, Ne
    I just picked this 28/29 coupe body up. It looks like I’ll have some ***embling to do, my question is does anyone have or know of a place to look for for an exploded body diagram? Just something I can look at to make sure I’m accurately ***embling it
    Tim and chryslerfan55 like this.
  2. Tim
    Tim
    from KCMO
    Now that looks like an adventure! There’s a bunch of you tube channeled that have covered this sort of stuff, my first look would be to bennets customs. But as far as diagrams they are pretty easy to find in all the BBC common model A books or by searching stuff like “model A wood kit diagram “ etc.
    what year/ body style is it? I can see what I have in my books. I’m guessing 28/9 coupe from what I can see.
    id probably try to get the subrails sorted and then build up
  3. Jacob1963
    Jacob1963
    from Omaha, Ne
    You’re correct it’s a 28/9 coupe. I’ll do some quick searches on YouTube. Thank you for the idea
  4. manyolcars
    manyolcars
    the ***embly is simple and easy to figure out. just start
  5. Corn Fed
    Corn Fed
    You post where you live, there might be someone here in your area that has one you can look at.
  6. alchemy
    alchemy
    I know someone in my area with a few you could look at. Probably has multiples of any parts you might be missing.
    32fenderless likes this.
  7. RICH B
    RICH B
    See if you can find a local coupe and get some pictures, if not maybe find someone to send you some.
    Then set the frame square & level on some stands; bolt the sub-rails down, next the cowl frame and it should go pretty good from there.
  8. Corn Fed
    Corn Fed
    Now that we know you are in Omaha. If you want to make the 2-1/2 hour drive over to my place I have a body you can look at and take measurements from. And I can show you all the little brackets you are probably missing (might even have extras available).
    Tim and RICH B like this.
  9. 49ratfink
    49ratfink
  10. Jacob1963
    Jacob1963
    from Omaha, Ne
    Ok fellas I’m making a bit of progress but I’m wondering if these pieces were used on 28/29 coupes and I’d so what are they called? Thanks for all the help so far. I’ll post some pics of my progress tomorrow when I get to the garage
  11. rusty_bits
    rusty_bits
    I did a post "time to give back", which shows my 1928 model a coupe ***embly.
    Tim and Jacob1963 like this.
  12. Jacob1963
    Jacob1963
    from Omaha, Ne
    Killer work!! Your pics helped me out big time Thank you!!
  13. alchemy
    alchemy
    Looks like the above the door brace. Will have thick wood bolted to the top of it and a trim piece screwed in from below.
