Technical 28-29 Model A Coupe T-strip, rust and paint?
Discussion in 'Traditional Hot Rods' started by IronFord, Dec 3, 2013.
  1. IronFord
    IronFord
    from NoDak
    So I'm in the process of disassembling our 29 sport coupe for blasting. The body is solid but has surface rust. I have removed the rain gutters and the panel below the deck lid. I'm debating on if I should remove the T-strips. I don't want any issues later on after the car is painted. Is it possible to seal the T-strips with something to prevent future issues? Something like panel bond? Or should I just say the hell with it and take them off?
    Thanks
  2. olskool34
    olskool34
    Don't not take them off! They are bolted and spot welded in between the body panels. I think any normal prep would be fine.
  3. Corn Fed
    Corn Fed
    If your body is solid with only surface rust, you probably don't need to remove them. Taking them off would be a major headache and will probably just ruin them and the quarter lip. I've had my 29 coupe in black paint since 1990 and it still hasn't had a problem.
  4. Thanks guys that's what we were thinking.
