28-29 model a cowl section
Discussion in 'The Hokey Ass Message Board' started by TANNERGANG, Aug 26, 2011.
  1. TANNERGANG
    TANNERGANG
    from alabama
    I'm wanting to build a Woodie...Anyone got a 28/29 cowl section...I need the post area, windshield, tank and sides....don't need doors or door hinges...I'm in Mobile, Al.....something within 250 miles would be nice...email pictures to TannerGang@aol.com or call Donnie 251-649-5397
  2. fiftyv8
    fiftyv8
    from CO & WA
    Might be worth being sure which post you need, as there are the sedan/coupe posts and then there is the pickup posts, both different.
  3. chaddilac
    chaddilac
    I've got a complete cowl with windshield frame, and one without windshield frame/A pillars.
  4. GlenC
    GlenC
    If you're building a 28-29 A woodie and you don't want it to look like it's been choped a few inches, you need to find a pair of 27 T coupe door posts. They're about 3 inches longer that even the A closed cab pickup posts, and are what ol' Henry apparently used to get the A woodie roof height he wanted. They do fit the A cowl lines fine, I imported a pair from the US back in the early 80's to build an A woodie, but sold it before it was finished.
    Cheers, Glen.
  5. sawzall
    sawzall
    first I have heard this..
    i have some things that might help you..
  6. Roupe
    Roupe
    Are you sure the door post are a different height? The '26-'27 coupes and the '28-'29 trucks use the same doors. They both have about a 4" header panel above the windshield.
  7. chopper cliff
    chopper cliff
    from lodi ca
    I had 4 28-9 p/u's doors are from 26-7 coupe or tudor sedan, I drive mine daily as transportation, fyi early 30 p/u is still square and still uses T doors. The 28-9-30 cowel is differentfrom the T but posts same, differences is in w/shield and header. doors getting hard to find oyeah diff in 29_30 is fuel cap. Cliff
  8. gnichols
    gnichols
    from Tampa, FL
    Are there any repop 28-29 cowl / firewall / toe board / A-pillar, etc. parts available? Gary
  9. belle
    belle
    i believe the woodie used a 28/29 pickup door posts , i'm not sure of any differences with a T coupe. check out this one:
    while this may not be the place for this , i do have an extra set of door posts if you are interested. they are a bit bent and the hinges are messed up
  10. GlenC
    GlenC
    Looks like my info was bad then... Bummer.
    It was back in the mid 80's, before the internet, and the HAMB of course. It didn't help that Australia didn't get closed cab pickups or woodies, so I had the rely on 'expert' advice as to what parts I needed to import to get the 'right' look. There's been a couple of woodies built down here using sedan cowls, and they're definitely too low in the roofline.
    Cheers, Glen.
  11. verde742
    verde742
    Some body makes the fibergl*** section you need to build a Woody,, I can't remember who,, but I remember the ad, It was what helped, and got me started when I dreamed my Woody together,,,, (..and It was Perfect)
  12. 29woodie
    29woodie
    from boston, ma
    You might want to start by joing the National Woodie Club. There's bound to be someone close who can help you. The club has plans for the Model A wood body if you are going the traditonal route. If you're going to make a phantom, well, anything goes. Good luck!
    By the way, you don't HAVE to use a Model A.....
  13. designs that work
    designs that work
    Tannergang,
    If you are using a stock wind shield your build would be similar to a stock Model A Woodie. Are you going to build a true woodie or a metal framed with wood hung on the metal? I have been working on a phantom woodie, metal framed, wood hung on metal. Never in my wildest dreams did I think it would be this hard! Do your home work, renderings or drawings to scale. Build a mock up out of cheap plywood to get a visual with out spending a lot of money. Do you have a table saw, router, and a wood planner? I could go on but I hope you get that it is not a slam bag project. Check out my album to get depressed. First picture is plywood mock up. Second picture first metal frame work. Third picture is final mock up, about the third and final design.
    More pictures in my album.
    Good Luck
  14. sawzall
    sawzall
    I am a director for the NWC. the club does have plans available for a Model A STYLE woodie body that was designed by mike chivetta (fully butchering mikes name)
    this is a photo of a stock model a wodie front door post..
    this attaches to the cowl and part of the hinge is attached to it..
    the door then screws to this hinged part.
    the "notch" seen in the door is for clearance for the driver side front fender mounted spare tire..
    personally havent ever had a "proper" model a woodie cowl.. so I am uncertain that a cowl posts are taller..
    I have however created reproduction model A cowls.. and could (and maybe should) make a proper model a woodie cowl (model 150A I.E. 28-29 only).
    the stock tank on the stock cowl on the right, slips right into the reproduction cowl on the left. this cowl later became a sport coupe style cowl and is destined for a later project.
  15. jipp
    jipp
    i want to build a bucket T.. iv been working with wood since i was 14 ( yay for wood shop and having a great shop teacher mr. chrow ) and have a shop of wood working tools.. i thought it would be easier for me to do this than learn fibergl***. but i cant say iv seen a woodie bucket/roadster.. has anyone made one and did it look good? i know you can buy a fibergl*** cowl from spirit industry.. so iv read but did not see it on there webpage.. i did not bother to email them..
    i would rather work with wood if i could.. thats for damn sure. heh
    chris.
  16. scrap metal 48
    scrap metal 48
    Brookville Roadster sells a phone booth steel pick up cab that is imported from Australia.. Maybe you should check with you fellow countrymen......
  17. GlenC
    GlenC
    Looks like I can now make up for my 'bad' info previously!
    Yes, there's an awesome hiboy deuce roadster pickup called 'The Freakster' built by the Woodie Works guy, who's a HAMB member too!
    It's a gl*** cowl with wood doors and pickup bed, and it's totally cool!
    Google for pics and info, there's a build thread on the woodie works site.
    Am I forgiven?
    Cheers, Glen.
