Custom Roadster Pick up panels... Available in Saddle, Black, Gray, White or Lipstick Red.... MADE to ORDER in 7 days. Shoot me your zip code for shipping quote from 43130. Panels are professionally covered with heavy duty vinyl. All panels are constructed of 1/8" lauan plywood and are padded with soft 1/4" foam for a nice look to the stitched sections. All of the patterns were taken from a Brookville Body and should fit a stock Ford Body. Please note: the kick panels are made to work around a stock gas tank. All panels can be clipped on (clips NOT included) or could easily be screwed on for a period look. Here's what you get: -2 door panels... All clip holes are punched as well as the location for the inside door handle (you can cut that hole if you need it... It is covered, so these are universal). -2 kick panels... with holes punched on the back for the stock door strap bracket. -2 rear quarter panels... again, all clip holes are punched. -1 matching shift boot -2 Door check straps Currently these are the only patterns I have, but hit me up if you have questions about other makes and models.... Thanks, Stitch
