Technical 28-29 Modle A B-pillars
Discussion in 'Traditional Hot Rods' started by IronFord, Dec 26, 2013.
  1. IronFord
    IronFord
    from NoDak
    Can anyone tell me if Ford used the same B-pillar in the 28-29 tudor sedans and the coupes? Or maybe the same b-pillars in the coupes 28 to 31? I have a 30-31 coupe carc*** and the b-pillars in that look identical to the pillars in my 29. The b-pillars in our coupe turned to swiss cheese after we blasted it.
    Thanks for the help
  2. fiftyv8
    fiftyv8
    from CO & WA
    Yes, 28/29 coupe and tudor are the same, I suspoect the 30/31 items would be very similar if not exactly the same.
    Proceed without fear...
  3. ty johnson
    ty johnson
    The only difference is that a sedan will have the rear window channel attached to the b pillar.
  4. Corn Fed
    Corn Fed
    As stated, the 28-9 coupe and tudor pillars are basically the same and you could put sedans into a coupe.
    IIRC, the 30-31's are slightly different than the 28-9's. Look on the bottom 1/2 of the inside and you'll notice that they are not flat all the way down like a 28-9. Is it possible to use these in your 28-9? Probably with at little work.
