'28-'31 Spindle for Model A pickup
Discussion in 'The Hokey Ass Message Board' started by Johnny50Bcc, Nov 5, 2013.
  1. Johnny50Bcc
    Johnny50Bcc
    from Italy
    Goodmorning to all!
    i'm Johnny from Italy. I'm searchin a technical information .
    Can i put a '39 ford drum brake to a '28-'31 spindle of a Model A pickup? Are they compatible?
    Thanks!
  2. HOTRODPRIMER
    HOTRODPRIMER
    I don't think you can. HRP
  3. sidevalve8ba
    sidevalve8ba
    Mac's offers a kit to do this. Part number X-2000.
    Try macsautoparts.com
    Ciao
  4. Bruce Lancaster
    Bruce Lancaster
    There are several kits of varying quality...you need 2 simple spacers. One is a ring that makes the raised circular part of spindle slightly larger so it fits the large hole in the brake plate, the other slides over the spindle pin and moves the inner bearing outward slightly because '28-35 spindle is slightly longer than the hydraulic ones.
    Once spacers are on, place brake on spindle and lengthen the bolt holes slightly so they meet the Model A bolt holes. Brake drum from '37-48 Ford will now go right on... it uses the same bearings even.
  5. 325w
    325w
    If I remember correctly a 6 cylinder Chevy piston ring will do part of the job. 3 9/16 ths maybe?
  6. Bruce Lancaster
    Bruce Lancaster
    Kit is a lot easier to get from Italy!
  7. HOTRODPRIMER
    HOTRODPRIMER
    Shows you what I know,,,Back in the early 70's I wanted to do this but I couldn't find any information about the conversion. HRP
  8. Johnny50Bcc
    Johnny50Bcc
    from Italy
    I have found it! Thanks a lot! :)
  9. Johnny50Bcc
    Johnny50Bcc
    from Italy
    Thanks for the clear explanation! :) i'll do!
  10. modelAsteve
    modelAsteve
    YES -Dennis Cling has kit or will do the work.
