Technical '28-'34 front suspension / big block question
Discussion in 'Traditional Hot Rods' started by RigorMorris, May 10, 2017.
  1. RigorMorris
    RigorMorris
    Will this suspension handle the weight of a chevy big block with aluminum heads
  2. They make a heavier spring for heavier engines. The steering box choice needs to be a bit stronger. Tire's have a wieght capacity also. Get those 3 nailed down and you won't have any troubles
    RigorMorris likes this.
  3. tb33anda3rd
    tb33anda3rd
    i am always amazed how heavy original engines are. the difference may actually not be that much.
    200 pounds maybe?
  4. 55chevr
    55chevr
    A lot of Chrysler hemi-s have been installed on early Ford suspension. Fenders, running boards removed. Weight difference not much. Posey's front spring would handle just about anything.
    Joe
  5. gimpyshotrods
    gimpyshotrods
    I hope so. I have a Chrysler 354 Hemi sitting on mine.
  6. FrozenMerc
    FrozenMerc
    An all iron BBC only weighs about a 100 lbs more than an all iron Flathead V8. Add in aluminum heads and intake, and your BBC will be right around the same weight as a Flathead. Most people don't realize how thick the walls and sections on early engines were before the engineers got a good handle on mold flow and core shift, which took until about 1958.
  7. RigorMorris
    RigorMorris
