Projects 28 CCPU build
Discussion in 'Traditional Hot Rods' started by G_Don, Mar 2, 2025.
  1. G_Don
    G_Don
    Its better than my phaeton in terms of room. I think the swing pedals, bucket seats being thin, and not mooving the firewall too much was key. Badshifter's model A firewall idea is great.
  2. lumpy 63
    lumpy 63
    You probably shoulda taken pictures of me driving it.....I wasn't sure I was getting out after shoe horning myself in:p
  3. G_Don
    G_Don
    Haha on her second maiden voyage (first one with doors) you were hesitatnt to get in, but you just couldnt resist a light pickup with a hot motor ;).
    You need to get an extended cab version of a 28CCPU going after your camaro!
    hook00pad and lumpy 63 like this.
  4. G_Don
    G_Don
    Made the fender braces yesterday. Used the existing pieces I cut off that go above the fender and attach to the outboard side of the fender and bent them to follow the outboard side of the fender going forward. Then bent up some 1/2" steel rect tubing to go from there to in between the carriage bolts on the main part of the fender brace. Hopefully it doesnt rub cause I really want to not put a spring lead back in teh front haha (I removed two from the low reverse eye spring kit).
    I'll be able to test drive it today but they feel stout. Any idea on other materials to use if they do rub? Would 1/4" tubing or channel steel work?
    Thanks.
    Gordy
    Tim, hook00pad, Deutscher and 4 others like this.
  5. Weedburner 40
    Weedburner 40
    I see not reason that wouldn't work.
    osage orange and G_Don like this.
  6. Moving forward and innovating. You're hotrodding!
    chlsnk and G_Don like this.
  7. G_Don
    G_Don
    Drove it today. Fenders shook a lot less (but still a little which I reckon is common when doing 70-80).
    No rubbing... Well maybe a little bit at the extremes but the same as it was before.
    Gonna paint em up soon and reattach them.
    Thanks for the great idea, weedburner!!
    Gordy
    Tim and hook00pad like this.
  8. Weedburner 40
    Weedburner 40
    You're welcome! Truck is looking great. Have fun with it.
    G_Don likes this.
  9. G_Don
    G_Don
    Anyone know if having a long grain stock model A vinyl top, if you can eliminate highway noise from in the cab? I feel like I've plugged every hole but still whistles lol.
    I have a couple theories....
    could it be the vinyl top?
    could it be the visor making a Billowing sound of wind?
    would punching louvers in visor help to get rid of the noise ?
    any help would be awesome!!
    hook00pad likes this.
  10. Weedburner 40
    Weedburner 40
    You probably aren't going to be able to get rid of all the noise but you can reduce it. If your windshield doesn't seal up rear tight, it could great wind noise around it. The most likely spot is the forward edge of the doors. These overlapping doors have what amounts to a scoop for air to come inside the cab. If you can put a small weatherstrip down the front of the door, you might be able to stop it. I have done this on my 34 coupe and still have wind noise. A good, tight fitting wind cord will do wonders too.
  11. MMM1693
    MMM1693
    Just outstanding!
    osage orange likes this.
  12. The phrase I use to describe the "ample" room in a 28-29 Model A truck cab is "kneecaps in nostrils." Once you've shoehorned yourself into one, you know what I mean. It's a dance, like the hokey pokey. You put your right foot in, you turn your right foot out, you swing your **** on the seat and turn it all about, you pull your left foot in you turn your left toes out, you slide your heal in and hope you don't fall out.
  13. G_Don
    G_Don
    Yeah I added some rubber gl*** bedding to the front of the door. Then some universal foam rubber to the tailgate side of the door. And some lower door seal gasket to the bottom of the doors. I plugged all the holes in the floor with dynamat, as well as above the windshiled on the header panel, I put some dynamat in the far outboard nooks and crannies next to the vinyl roof. The noise went from a deeper billow to a higher pitched whistle (which I think means it has to get worse in order to get better lol)
    The windshield frame doesnt have the tightest fit. Could be tighter. Maybe ill start playing with that next.
    I did want to see if taking the visor off would help at all.
    Anyone know a good louver guy in San Diego CA? I guess I could venture up to LA but really would prefer not to.
    haha I could also do speed holes, but theyre kinda crude, not that my truck is a peach by any means lol
    Thanks!
    Gordy
  14. Weedburner 40
    Weedburner 40
    Check with Randy Clark at Hot rods and Custom Stuff in SD. He might know of a louver press.
    G_Don likes this.
  15. G_Don
    G_Don
    I will call him on Monday!
    Thank you
    Gordy
  16. G_Don
    G_Don
    IMG_5993.jpeg IMG_6016.jpeg Colin and Butch helped me thrash on getting my rear fenders fixed up and then I put on commercial running boards. Happy with the fenders now. Next is cutting out the spare tire and fitting in a nice smooth piece from a donor fender I have... and brush painting the bed, one door and hood dark green.
    AHotRod, Dave Mc, treb11 and 7 others like this.
  17. patsurf
    patsurf
    sorry if already told-but why not 'enjoy' the tire well?
  18. Tim
    Tim
    from KCMO
    You’re taking one out and I’m probably going to try to add one to a fender I have lol. I’m gonna make Louvered “lids” for the wells and use them
    For road coolers when they aren’t holding a spare haha.
    love your fender brace solution. I’d thought of something similar but hadn’t considered going forward with the loop which I would think would really stiffen them up.
    I would consider adding some bump stops instead of adding a leaf if things are still rubbing more than acceptable
  19. Johnny99
    Johnny99
    Von Dago likes this.
  20. 05snopro440
    05snopro440
    This truck is so good. What do you think of the saddle tanks now that you've been using it a bit?
    Just curious, have you straightened out that right side bed rail and if so how did you do it? Mine need some straightening and I'm not sure how to manage that without crushing the square edge.
  21. G_Don
    G_Don
    did straighten that out. Colin showed me. We just took a cherry picker and got 90% of it out just jacking it up where it was kinked. We also used a slide hammer and tried pulling it out and got a good portion of it fixed. Good enough for this truck.
    I don't mind the saddle tanks. My fuel gauge needs some attention so it's nice that when I run out of gas on the left side, I switch to the right side and then make sure I fill up the left side sooner than later. lol
    I'm definitely filling the spare tire well. Haha
    also can't take credit for the fender braces. That was all weedburner40s idea! And I love it!
    Gordy
    Dave Mc, Tim, brad2v and 4 others like this.
  22. G_Don
    G_Don
    Me and Colin put a moto meter on. It's extra large wings are ridiculous but I really dig em.
    My dad was visiting and we ended up painting the cab rustoleum satin hunter green and added some black to get it darker to kinda act like that basalm green from a stocker model a. Really shows off how hammered my back panel is haha but whatever.
    was a little sad to see patina go, but it'll be protected cause I live in the most southwest town in the US.
    Highway noise is still terrible haha. I gotta think guys like Jake didn't deal with his truck being this loud. I'm wondering if the exhaust only coming to about the rear end or even an exiting forward of the rear is causing a bunch of reverberating. Any help on this would really help!
    gordy
    AHotRod, lumpy 63, Dave Mc and 5 others like this.
  23. Weedburner 40
    Weedburner 40
    First, I LIKE IT. I am not a big "patina" fan so the all one color looks good. Second, the exhaust ending under the car will resonate back inside. Bring it back further will help. Without a full interior, the cab is just a bid drum so will be noisy.
    Tim, G_Don, 05snopro440 and 1 other person like this.
  24. G_Don
    G_Don
    Yeah I'm not a big patina guy unless it all came from the same car. The nice thing is I won't have to worry about this paint job! Lol the bed is next!!
    I think I'm gonna go under the rear, then bend up and bring the exhaust just under the bed all the way to the back. Start there, and put dynamat on the floor and doors and firewall. See if that helps.
    AHotRod, Tim, hook00pad and 2 others like this.
  25. G_Don
    G_Don
    Made exhaust longer. They're kinda even... I'll rework it down the road.
    Anyone for a less hideous exhaust hanger/muffler clamp solution? Haha
    definitely less resonance in the cab. So that's pretty cool! Wind noise is still a little bad but better than a week ago. Got some foam strip to put on the front edge of the door. Hoping that helps a bunch.
    Cool pic of it on the street.
    Next is putting another ford emblem on grill shell and grill shell lacing. As well as insulating the doors, and cutting a piece of rubber mat I ordered from McMaster Carr for the floor .
    Debating on down the road narrowing axle 1" on each side. They're those long splined axles so it wouldn't be too much involved (antleast not with money, just my time, which is worthless lol) I'm only gonna run these wheels on it. And I think it would stance it better having the tires not sticking out, and allow me to go slightly lower in the back.
    Gordy
  26. 05snopro440
    05snopro440
    That gave me a good idea, I might be able to use my porta-power to the floor with some well placed hammer blows to straighten mine out. Mine is more rolled over than pushed down like yours. Thanks!
    Glad to hear the saddle tanks are working out for you. That might be a way to keep my bed more usable.
  27. G_Don
    G_Don
    Yeah, I'm happy I did them. Pain in the **** to put in and gonna be a pain to figure out my gas gauge but whatever. Lol. I went to RPM nationals swap meet to sell parts and took truck (Forgot to take pics), and I'm glas I didnt have a gas tank back in the bed. I fit a 34 hood, 4 kelsey hayes wires, model a running boards, two sets of rear fenders and some drums and backing plates back there with no issues.
    Gordy
    05snopro440 likes this.
  28. G_Don
    G_Don
    A new emblem in. 30/31 style. Think it looks cool. One of those lower rad shell swing things I guess for setting timing with a B motor. And the radiator welting on. Was a pain in the **** but I got in a rhythm.
    and then I made a rubber mat. It's almost perfect but I messed up a little bit.
  29. G_Don
    G_Don
    Thinking of doing some spray insulation foam in the header for wind noise. The door sponge type foam at the front of doors near A pillar didn't really help. Thinking it's all in the visor.
    was gonna use "great stuff" foam but does anyone have any good recommendations for spray foam so it will be more air tight up on the header where the visor bolts to and the rear view mirror bolts in??
    thanks!
    Gordy
  30. Grumpy ole A
    Grumpy ole A
    That swinging door “thingy” is to hand crank the banger. With some practice you can hand start it.
    05snopro440 and Von Dago like this.
