Hot Rods 28 Coupe Build Pics... Thrashing for the Round Up?
Discussion in 'The Hokey Ass Message Board' started by Biggy, Sep 11, 2009.
  1. Biggy
    Biggy
    from Texas
    We started thrashing ******** last week with the hopes of getting my car ready for the Round-up. The build has already been delayed due to some incorrect incorrect parts, and now we are waiting on Mummert to finish my y-block bell housing so we can make the ****** mount.
    Tommy Jackson and I started with a stock frame that had been boxed and we gave the front of the frame the Bleed sweep that holds a stock front axle dropped by Okie Joe.
    The rear is suspended by a 40 ford front spring and will be getting some homemade ladder bars soon.
    The motor is a 292 Y-block that will be adapted to a 5-speed shortly.
    The body is a Ford AR Coupe that I got out of Oklahoma. I have no history on the car and I am looking for some insight on the best way to channel the body.
  2. Dreddybear
    Dreddybear
  3. 60'shotrod
    60'shotrod
    YEP!:D
    Nick.
  4. smith32
    smith32
    Looks like a start to a nice project, i see you and I are both shooting for the same goal here....... RoundUp 2010
  5. scrap metal 48
    scrap metal 48
    Looks like your rear spring hangers are upside down and the shackle could hit it once under weight.........
  6. chaddilac
    chaddilac
    keep updating!! I hope to be there in my T coupe too! ....well maybe?:D
  7. 94hoghead
    94hoghead
    looking good!
  8. Biggy
    Biggy
    from Texas
    Got the wishbone mounted. We chose to go with these radius mounts instead of rod ends.
    You get a good view of the front sweep here.
  9. bob1940cab
    bob1940cab
    Big A,
    Yours looks way better than mine.
    Be careful.
    Bob 1940
  10. Cut55
    Cut55
    from WA
  11. pecker head
    pecker head
    Nice build , I love the Bleed sweep , will be doing on my 4dr project . What does AR stand for ? Looks like a special coupe to me .
  12. nailhead terry
    nailhead terry
    flip those hangers I found out the hard way neat car I hope to have my 3 window there what ****** ?
  13. Biggy
    Biggy
    from Texas
    I don't know any history on AR, but I believe it was an early A Body with T running gear. I looks to me as if it were a special coupe that had been welded up. The body had been p***ed around a few times and the fellow I bought if from has no history on it.
  14. Biggy
    Biggy
    from Texas
    I am scared that if I flip the hangers I won't have any frame clearance.
  15. pasadenahotrod
    pasadenahotrod
    from Texas
    AR, or early 28, is simply a designation for the first hundreds of As which have features which were discontinued during production but were sold.
    These features include the left-side hand brake, the multi-disc clutch, open-ended bumpers.
    There were no Model As built on T frames or with T running gear.
  16. pasadenahotrod
    pasadenahotrod
    from Texas
    If you don't flip them you won't have any suspension clearance, as in the suspension won't be working.
    While you're at it you might widen them out a bit to get the spring under tension and add a gusset or two to stiffen them up. That might just end your fears of frame clearance problems too.
  17. holeshot
    holeshot
    from Waxahachie
    hey biggy... i love those old 292s it doesnt take much to make them holler. i heard the only way to put lifters in. is to turn the block crank side up- and drop the lifters in and then load the cam. is this true? just call me pop.
  18. Biggy
    Biggy
    from Texas
    Call John Mummert a Ford-y-block.com. He is a Guru.
  19. holeshot
    holeshot
    from Waxahachie
    hey biggy... if you need any professional metal work done. dreddy bear is the man to see. that man is an artist with metal. call me pop.
  20. Toqwik
    Toqwik
    Biggy, I think you body man and mine are related. My rear wheelwells look EXACTLY like yours. Nice project you have there.
  21. Biggy
    Biggy
    from Texas
    We moved the rear spring mounts further apart and added the gussets. Installed some motor mounts and built the trans cross member. Started the ladder bars and we are waiting on some bar ends to be delivered.
  22. VAPHEAD
    VAPHEAD
    Looks like a Posies AJ40NH rear spring.
    The hangers should be 44" apart.
    You got them upside down,and the gusset normally goes to the inside.
    Might as well fix it now instead of later.
    You shackles will bottom out by the time you put a body on it.
    Not trying to bust your chops.
    (we do 3-4 of those a week)
  23. Bloody Hell
    Bloody Hell
    from Spring, TX
    Did Tommy sell that dreamy Shoebox?
