28 Coupe Build
Discussion in 'Traditional Hot Rods' started by 51box, Jan 16, 2016.
  1. -Brent-
    -Brent-
    This build is exceptional. There are some really great details within this thread.
    kidcampbell71, Mikel50 and 51box like this.
  2. vtwhead
    vtwhead
    post the video to youtube and copy the URL over to here......we are anxious to here that run:)
    51box likes this.
  3. NorthRiver6478
    NorthRiver6478
    51box likes this.
  4. mike bowling
    mike bowling
    Man, what a great job you've done. (I came down to your place with Mike L. when you sold a " roller" to Ronnie W.) That's going to be one sharp rig!
    51box likes this.
  5. 51box
    51box
    from MA
    Thanks guys, it’s coming together
    Let’s see if this works
    It had just fired it and was around 2k rpm I started to take the video, notice no water temp yet but it came up to around 190 and stayed .
    https://m.youtube.com/watch?sns=em&v=55B54kiQKVA
  6. 51box
    51box
    from MA
    Thank you I appreciate it, I’ve learned so much on this car.
  7. oldrodder43
    oldrodder43
    This may be your first hot rod build, but it's definitely not your fist Rodeo guy. Amazing work.
  8. mike bowling
    mike bowling
    Always makes me nervous when you first start a new motor and things start smoking! That sounds killer, and the side by side intake is super cool.
    panicmike likes this.
  9. amazing build, thx for sharing with us
  10. 51box
    51box
    from MA
    Picked up a new condenser from vertex and it fired back up so that’s a good sign. I was able to pick up the marks with a timining light which is a ****shoot with mags. It’s steady at 32 degrees so I think the mag is good to go now.
    Here’s a quick video with a couple blap blaps !
  11. Nailhead A-V8
    Nailhead A-V8
  12. wheeldog57
    wheeldog57
    Yowza Joe! Looks and sounds great. You have come a long way in a short amount of time. See you out there
  13. brEad
    brEad
    Somehow became unsubscribed to your thread. I missed a lot of great work. Engine sounds healthy!
    kidcampbell71 likes this.
  14. Angry Frenchman
    Angry Frenchman
  15. 51box
    51box
    from MA
    Prime & block and prime & block....... hopefully someday soon some paint??? BA4B3F4B-04FB-4DB3-87B3-CDE74159EC0F.jpeg
  16. 51box
    51box
    from MA
    Little bit closer
    Fit up the belt line and put the final coat of primer on.
    Then shot the inside over the weekend
    Hope to paint the outside in a couple weeks
  17. 51box
    51box
    from MA
    05961FB4-7E3F-4D66-9C76-2D96E7F38BB6.jpeg Couple things to ****on up but very close to ready once I get some paint on the body.
  18. nailheadroadster
    nailheadroadster
    Very impressive 51box!
    51box likes this.
  19. NorthRiver6478
    NorthRiver6478
    Smooth...Everthing is flowing...Great Job
    51box likes this.
  20. 30tudor
    30tudor
    How did you make up the belt line? Any tips or pictures of that area? Thanks.
  21. RoddyB34
    RoddyB34
    Great build there ,,I really like the use of the late 3 speed with the top shift ,,simple ,,,cheap ,,,replicates the earlier Toploader setup but with strong reliability ,,the stick comes up in the right spot too,,how many gears do you want to be rowing through ?
  22. 51box
    51box
    from MA
    The belt line is the original leather back piece. I welded studs to it instead of attaching with nails like original. It has a bunch of small nuts inside I just tightened up on and seam sealed in between .
    brEad likes this.
  23. 51box
    51box
    from MA
    Thank you, I went with the 3spd because the Nailhead is all low end grunt no rpm engine. 3.50 gears with ~32” tall tire. She will have some nice long legs with this setup
    wheeldog57 and brEad like this.
  24. 51box
    51box
    from MA
    Finally was able to paint the body, took me about three (maybe four) times longer then I thought it would to body work but it feels damn good to hit this point. I used some Nason single stage and a harbor freight hvlp gun to do the deed D77BA892-F64A-4136-818F-2102E47F4B22.jpeg
  25. brEad
    brEad
    That looks pretty darn nice from here!
  26. LSJUNIPER
    LSJUNIPER
    from ct
    Great build, Mine is going a little slower, learning a lot watching your build. I see your from MA, I'm from CT maybe I will see your car at one of the shows soon.
  27. vtwhead
    vtwhead
    And now a painter to boot! Nice job, she sure looks purdy.:)
  28. 51box
    51box
    from MA
    Thanks man its been a lot of hours sanding
  29. wheeldog57
    wheeldog57
    51box likes this.
  30. 51box
    51box
    from MA
    Thank you, will hopefully be on the road next season
