28 ford 4 banger
Discussion in 'The Hokey Ass Message Board' started by hotrod-28, Nov 30, 2011.
  1. hotrod-28
    hotrod-28
    from dayton
    Hello i have a 28 ford sedan that im builling and i was thinking of useing a ford ranger 4 banger in it but wich ranger motor is best ?
  2. caseyscustoms
    caseyscustoms
    from st.joe, MO
    google would be a good start.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    There is a thread on here about the 1.9,2.0,2.3 engines which will tell you all you need to know about these engines. Search...
  4. George Miller
    George Miller
    from NC usa
    What do you want to do with it. The later A blocks have a stronger main web. 28 have a 5 main camshaft. I have used both with good results. Some like the B engine better, they have bigger bearings on the crank. But they crack easier in the valve area.
  5. cruzr
    cruzr
    My buddy owns this one, its running a Pinto engine with a 39 ******
  6. John Denich
    John Denich
    My Buddy Rick has a track-T with a Pinto in it and drives it everywhere! It was in Rodders Journal about 10 years ago....its Yellow very reliable!
  7. Ebbsspeed
    Ebbsspeed
    I think all the Ford Ranger 4 cylinder motors had 5 main and camshaft bearings. You might not have understood that he is considering using an OHV motor, rather than the early Ford banger.
  8. I have a '32 Ford roadster with a 181 cubic inch Mercruiser marine engine. I made this conversion in 1985. This is basically a larger version of the old Chevy II engine (there is a ton of information on these engines in the archives). I am happy with this engine since a simple adapter intended to mate a SBC to an early Ford transmission (this is what everyone was doing in the sixties and the adapters are available at swap meets or new) allowed me to run a '39 transmission and the stock rear end. The installation in a Model A is slightly more difficult since you need to make provisions for the pedals and wishbone mount (kits are available). If I had it to do over I would leave the original engine in the car but this is in no way a reflection on the conversion, I just tend to lean more towards original especially as I get older. The nice thing about this conversion is that it required no cutting and can be reversed.
    Charlie Stephens
  9. hotroddon
    hotroddon
  10. George Miller
    George Miller
    from NC usa
    You are right my fault I read it wrong. I though he wanted to know about Model A engines. I read it again and seen where I messed up.
