Hot Rods 28 grill shell question
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Nov 14, 2022.
  1. jjjmm56
    jjjmm56
    from FL.
    How could I tell if a grill is original
  2. FORDY 6
    FORDY 6
    Looks like an original 1931 shell
  3. rusty valley
    rusty valley
  4. HOTRODPRIMER
    HOTRODPRIMER
    Yeah, 1931 Ford. HRP
  5. gimpyshotrods
    gimpyshotrods
    Not at all original to 1928.
  6. Like others said its for a ‘31
  7. alchemy
    alchemy
    Probably on the drafting table in 1928.
    wood remover and gimpyshotrods like this.
  8. Primered Forever
    Primered Forever
    from Joplin,MO
  9. jjjmm56
    jjjmm56
    from FL.
    Thanks, it was an extra that came with a project I picked up over the weekend
  10. You would have to cut it up to work on a '28, please don't.
    Charlie Stephens
  11. jjjmm56
    jjjmm56
    from FL.
    I'm not using it at all, I was also given a 32 grill that I will be using. I'll most likely put the 31 grill up for sale
  12. low down A
    low down A
    curious if your 32 grille is a 32
    Mechman_22, irishsteve and Jet96 like this.
  13. vtwhead
    vtwhead
    And what project was that JJJmm?
  14. jjjmm56
    jjjmm56
    from FL.
    31 tudor can't show picture because of the wheels the last owner had on .
  15. 1946caddy
    1946caddy
    from washington
    So you bought a 31 Ford and it came with a 31 Ford grill shell.
  16. jjjmm56
    jjjmm56
    from FL.
    Thats what he said it was. All I asked is how to tell if it's original or a repop. It also came with a 28 frame, which the numbers match the paperwork.
  17. rusty valley
    rusty valley
    I don't think the 31 shell has ever been reproduced.
    gimpyshotrods likes this.
  18. jjjmm56
    jjjmm56
    from FL.
    Thank you
  19. 1946caddy
    1946caddy
    from washington
    [paste:font size="5"]1928 Model A Ford Instruction Book, Ford did in fact specify the engine number to be the 'serial number' of the vehicle, during the Model A (and B) era, and throughout the 1930's. The Specifications and License Data page above in the Instruction Book is quite clear and specific about this.
    It is popularly but incorrectly claimed that the serial number of the vehicle was a frame number. Actually, not all Model A vehicles even had a frame number. A great many did not have a frame number stamped, and it varied depending on when and which of the more than two dozen ***embly plants completed the vehicle final ***embly. There is no Ford literature available indicating a frame number was ever intended for any primary identification of a vehicle by Ford.
    When present, the frame number was a duplicate of the original engine number of that ch***is. The engine number was ***igned and stamped at the Rouge and was usually, but not always, later stamped on the top of the frame flange at the vehicle ***embly plant as a backup to aid in positive identification of stolen vehicles. In the 1930's, vehicle theft was actually quite a large problem.
    A check for a possible frame number requires removal of the body and fender splash aprons from the frame. Any number present is frequently obscured or illegible due to corrosion and pitting from moisture held by the cotton frame webbing between the frame and body.
    The engine number, not a frame number, was the original serial number of the vehicle for ***le and registration purposes. This is true throughout the Ford Model A and B US and Canadian production era.
    reference; https://www.fordgarage.com/pages/ABenginenumbers.htm
  20. How about some photos of the body etc?
    Charlie Stephens
  21. jjjmm56
    jjjmm56
    from FL.
    Yes I found this info 10 years ago when I built my 36
  22. jjjmm56
    jjjmm56
    from FL.
  23. X38
    X38
    Or suspension!:eek:
  24. jjjmm56
    jjjmm56
    from FL.
    yea not a fan of that, but I have a 28 frame too.
  25. alchemy
    alchemy
    What did they do to the wheelwells?
  26. jjjmm56
    jjjmm56
    from FL.
    I don't know what they were thinking. I'm going next weekend to find some fenders so I can recut the openings
  27. 1946caddy
    1946caddy
    from washington
    FYI, All p***enger and pickup frames are the same for Model A's from 1928 - 1931.
