Projects 28 model A Coupe build--first time
Discussion in 'The Hokey Ass Message Board' started by reyn, Jan 25, 2015.
  1. bengeltiger
    bengeltiger
    Thanks for the reply. I'm subscribed and along for the ride.
  2. bschwoeble
    bschwoeble
    You are to be commended. I like the I'm going to do this at***ude. That is what hot rodding is all about. I've always believed in the if it wasn't created by God, I'm going to try to fix it or make it.
  3. panheadguy
    panheadguy
    from S.E. WI
    You could try to simulate this happening....Would the suspension still work with heim joints instead of the urethane bushed ends of the upper control arms?
    Love your project and you are a talented guy. Any chance your past life was as a tool maker?
  4. reyn
    reyn
    Not sure if heim ends would work. I might need a panhard bar the way it is. First saw Malcolm's build here on the hamb and thought 1/4 elliptical springs were the way to go. He mentioned in his build how the suspension worked great, so I thought I would try it.
  5. reyn
    reyn
    Testing
    dalesnyder likes this.
  6. reyn
    reyn
    I finally got to posting a few things that were done in
    August.
    Put the body in molas*** for about 3 weeks and was really impressed. I can't think of an easier
    way to remove rust.
    It took all the rust off, even the paint. Pressure washer took everything off. Metal prep removed all the flash rust leaving a nice grey surface. Then finished with epoxy.
    104.JPG 105.JPG 106.JPG 107.JPG Also finished the exhaust. Some tight fits. Not too much for starter and oil filter clearance, so I plan on using exhaust wrap down to the mufflers.
    Have never used it before. Not sure how much it cuts the heat down. Guess I'll find out.
    That's it for now. Since August, been busy adding on a small addition to the house and redoing the kitchen, dining and living room. Just finishing up. I can not wait to get back on the coupe, after I dig it out.
  7. GT46
    GT46
    WOW! Impressive keep it going.
  8. Torana68
    Torana68
    from Australia
    what % is the mol***as bath?
  9. reyn
    reyn
    It is about 9:1 I bought 4 , 5 gallon pails of mol***as and the rest was water. The tank held around 190 gallons.
    Reyn
    oliver westlund likes this.
  10. Torana68
    Torana68
    from Australia
  11. bjinx
    bjinx
    Nice work. What make and year are the exhaust hangers.
  12. D.Conrad
    D.Conrad
    Great build, just subscribed. Keep it up.
  13. reyn
    reyn
    They were laying around the shop for a few years. I don't know, but have seen them in a few auto stores.
    Canadian tire up here in Canada. Should not be too hard to find.
  14. chargin03
    chargin03
    Love your work!
  15. bjinx
    bjinx
    Thks.
  16. Tim
    Tim
    from KCMO
    Looking good!
  17. reyn
    reyn
    Finally getting back to the coupe. Made some pads for the clutch and brake 114.JPG 116.JPG 117.JPG Finishing the firewall 118.JPG 118b.JPG 119.JPG 120.JPG 121.JPG Trying to get the subframe going. There are many ways to do it. I'm fumbling through it as best as I can 122.JPG 123.JPG 124.JPG 125.JPG 126.JPG 127.JPG It's just a series of problems that need to be solved.
    Started on some sheet metal in order to get the cowl mounted. Then the front mount of the subframe could be finished off. 128.JPG 129.JPG 130.JPG The welds need some work yet. 131.JPG With the front mounts done, the cowl is solid. Now to start working my way back. 132.JPG Getting the body put together in one piece is my worst fear. It will be a challenge.
  18. whtbaron
    whtbaron
    from manitoba
    I've been by Humboldt a few times on my way out west. If I had known things were this interesting I would have stopped. Nice work!
  19. Bader2
    Bader2
    Hey reyn,you know any of the gaetz family from humboldt? Brians a good friend of mine. Or any lukans?
  20. reyn
    reyn
    Stop in any time. I can use the input.
  21. reyn
    reyn
    Bader2 I know of the gaetz. It is a familiar name here. I know Aaron Lukan. Good guy.
  22. reyn
    reyn
    I have the doors on. The drivers is ok. The p***engers door has been sprung at one time. It is within 6" of closing at the back. 134.JPG 135.JPG
    I have some beat up extra doors with the drivers door hinges good. They look like they could be switched side to side. Any ideas as the best way to fix this. Can they be heated and brought back into alignment? This must be a common problem. I'm sure someone has a solution. 137.JPG 138.JPG 139.JPG
  23. Jet96
    Jet96
    from WY
    I just stumbled onto this thread. Dang, I need to go take a nap after seeing all the work you've done! You've probably already got feedback, but yes the exhaust wrap works great. Use constant tension clamps instead of the funky little bands it comes with. Keep on building !
  24. Bader2
    Bader2
    Skin looks ok,looks like its sprung in the hinge area,fairly easy fix with heat in the right places. Id bet if you put the two doors side by side,the differences would jump out atcha.
  25. reyn
    reyn
    Thanks for the hint
    I don't think it would take much either. I'm not in a hurry to screw up. Have to try setting them side by side.
    Thanks
  26. reyn
    reyn
    Well, it has been too long since the last post. Time keeps flying by. It sure does feel better to get back into the shop. I left the body for a while and got the engine ready to go. Painted it up. Rebuilt the three 2g's and ran the fuel lines. Then machined some br*** for the home made linkage. 133.JPG 134.JPG 135.JPG 135a.JPG 135b.JPG 135c.JPG Just need to finish valve covers and buy a set of plug wires.
    This month I got back at the body. Made a buck and hammered out some wheel wells and tacked them in. 137.JPG 138.JPG 139.JPG 140.JPG
    Cut out the bottom 4" on the rear quarters, made some patches and tacked them in 141.JPG 142.JPG 143.JPG 144.JPG
  27. brEad
    brEad
    Glad to see you back at it! Looking good!
  28. reyn
    reyn
    152.JPG With a little slicing and dicing and I'm happy with the fit. 153.JPG 154.JPG
    Made a piece for the english wheel to bend tubing for the trunk. 155.JPG 156.JPG
    It takes a lot of pressure and the frame really springs. A come-a-long fixed that. 157.JPG 158.JPG
    The tubing deforms when it is bent a lot, so I had to put in some relief cuts to finish it off. 159.JPG 160.JPG 161.JPG 162.JPG
    I an building the trunk lid the same way "3034" on the hamb did his. Thought it was a great idea, so I am copying his idea
  29. reyn
    reyn
    The panel below the trunk was rusty and needed some work so I made a new one. 163.JPG 164.JPG 165.JPG 166.JPG 167.JPG 168.JPG 169.JPG 170.JPG
    I am pleased with the results, although having more tools sure helps. Stretcher-shrinker is amazing for such a simple tool.
    Just getting into the bead roller. Made some tipping dies. Life just gets easier. 171.JPG 172.JPG
    173.JPG 174.JPG 175.JPG Even threw an old angle grinder head in to get the speed down where I wanted it.
  30. brad2v
    brad2v
