Hot Rods 283 bored .060
Discussion in 'The Hokey Ass Message Board' started by Aaron Lankford, Jan 26, 2017.
  1. Aaron Lankford
    Aaron Lankford
    DP carbs came on a 65 327. 4150?
    I haven't poured the heads yet, info provided by machine shop. I'm sure I'll come up with a question or two, as I tear it down.
    Also may give me some info. I'm curious to know what cam is in there now.
    I can't ask the previous owner,as he is deceased. Hard to believe someone takes a 283 bores it .060 with pop-ups and didn't cam it.
  2. Aaron Lankford
    Aaron Lankford
    That's prettygood!
  3. DDDenny
    I don't think so!
    Pretty sure the first oem Chevy with the double pump Holley was 67 Z28 302 and big blocks.
  4. No. No, and no.
    This is going to come as a shock to some of you younger folks especially .The DP Holley was released in the mid 60's as a high performance replacement .It came stock on..NOTHING.
    Probably a good thing, too. Emissions regulations would have been even stiffer.
    Frontwards or backwards, all vacuum secondaries:
    1964 138211-500-0.jpg 1969 0403_03z+1969_Chevrolet_Yenko_Camaro+Engine.jpg 1965Strong-Arming-HEMI-engine.jpg
  5. Fordors
    Fordors
    The '68 L88 had an 850 DP, as compared to the '67's vacuum secondary carburetor. Also, the over the counter Trans Am inspired cross ram used (600cfm?) double pumpers.
    I think it was 1968 when Holley introduced the DP's as List numbers 4776- 4781, 600 to 850 cfm. Later, in the '70's they also had a few emissions/performance DP's like their Quadrajet replacement carbs.
  6. Okay..I knew this stuff would come up.I should have clarified in the beginning.
    RPO, showroom available, etc. Not over the counter , dealer options, etc. .
    The L 88 was not sold as a street motor.
    What this all has to do with vintage looking 283's, I don't know.
    We still don't know what the o/p's certain look is that he's striving for. ??
    Of course, we spent 3 days last week ,on a 327 pipe dream, so nothing surprises me anymore. LOL
    belair and Aaron Lankford like this.
  7. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Maybe that's a mill al tschida built.....he won '64 c/gas at Indy
    283 bored .060
    Approx 13.5-1 comp
    Racer brown roller cam with rev kit .505 lift. Crane alum rockers
    Home ported/polished F.I. Heads milled .060 lightest valves available
    Early small hilborn injection. Vertex mag 38-42 total advance
    Heavy steel flywheel & clutch by E&R
    Factory crank, used M/T aluminum rods in most but unsure on this one
    Homemade headers
    8,000 rpm
    Aaron Lankford likes this.
  8. DDDenny
    My comment was basically directed at the OP's statement as to "dp" Holleys coming out on 65 327's, that is for a fact not true.
    I am old enough to remember taking my high school pal to get a used 68 Z28 in 1971.
    They also weren't supposed to come with the JL8 four wheel disc brake option in 68 but this one did.
  9. Aaron Lankford
    Aaron Lankford
    I don't mind if people get on this thread and wander off. I'm sure ther is a lot of bench building, too.. I'm getting into motors and hot rods.. sorry, guys I just didn't grow up building motors.
    I ask questions, because I don't already know the answer.
    Thank you too everyone who had put forth positive info. I appreciate it.
    lothiandon1940 and loudbang like this.
  10. Aaron Lankford
    Aaron Lankford
    Dogger likes this.
  11. Aaron Lankford
    Aaron Lankford
  12. Aaron Lankford
    Aaron Lankford
    Cool story. Wth does this have to do with a built up 283???? So, I'm not a Holley carb tech, and as I've state before in this thread I'm knew at this stuff. If you don't have anything useful to put forth, then move along.
    Some of you guys on here just like trolling people's threads.
    Some of you have been great and I/we are thankful.
  13. DDDenny
    Aaron
    You did say you don't mind people wandering off on your thread.
    You are absolutely right though, a lot of us do that, I guess it comes with age.
    I'll try and keep the HAMB dry and humorless from now on.
    belair and ct1932ford like this.
  14. Torkwrench
    Torkwrench
    It's a 1960 283 that was originally built in about 1968 by a guy in Fairview ILL. At that time is was bored .080 with Jahns 12 1/2 cast pistons. This was with a set of 2.02 fuelly heads, 300 Hp. 327 cam and intake. The carb was a Carter AVS of unknown CFM.
    My older brother bought the engine in 1970 and installed it in his 57 Chevy Sport Sedan. At about this time, it got a 375 Hp. 327 cam, and an Edelbrock Tarantula intake. The carb was also changed to a 780 vac. secondary Holley off of a, (then new and newly wrecked), SS 454 Chevelle. By the way, the Chevelle was in a junk yard, (Ace Auto Salvage), in Bartonville ILL. at that time.
    I bought the engine and installed it in my 55, in 1977. Currently, it is still basically the same as it was in about 1970. However, I had it bored out to 301, in 1984. The pistons are now TRW factory replacement forged pistons for a 302 Chevy. The compression is 11:1. This machine work was done at D & D Speed and Machine in Peoria ILL. Later, it was freshened up in 1998.
  15. Aaron Lankford
    Aaron Lankford
    I don't think dry and humorless would be any fun! As far as "wandering off"... I did say that, because I was trying to be polite to people who were sharing info on old builds. Listening is a great way to learn.
    That's a bit different than some smart a** remark by a person/s who aren't offering anything substantive.
    Have a nice day!
  16. Aaron Lankford
    Aaron Lankford
  17. Aaron Lankford
    Aaron Lankford
    Thanks man! I appreciate you sharing this info. I enjoy hearing how guys set up their old builds! I'm probably overthinking mine a little.
    Thanks again
    Torkwrench likes this.
  18. Im looking forward to hearing how your build is going.....please keep us in the loop....with pics !!
  19. Aaron Lankford
    Aaron Lankford
    I definitely will!
  20. Candfury
    Candfury
  21. Aaron Lankford
    Aaron Lankford
    Thanks! Not super concerned, at the end of the day, what it came out of. I'm just overly inquisitive about stuff like that, lol!
    What I am excited about is the car build!!!
    For fun, I'm going to build it like the 300hp/327 L79.
    Car is a 39' Chebbie Coupe. I'll post pics as it goes along! Thanks for the link!
  22. Some things to think about . . .
    Camshafts and valve train components/technology have come a long way from back in the day - some of that has to do with valve spring technology, but also all the various rocker arm packages, roller rocker designs, etc - that didn't exist in the 60's. I like the 461 heads - ran those on quite a few 327's. If it was mine, I'd have the heads street ported (at least good bowl work done), put in high quality pro-flow type valves (Manley), put in 7/16 screw in studs and pushrod guide plates. I'd also run a mechanical roller cam, beehive springs and a quality set of aluminum roller rockers. Having a well built top-end will allow the 292 to breathe and to have a stable valve train at higher rpms.
    Once you know your complete package (engine specs, trans and gears, rear end - car weight, usage goals), then give the guys a call at Bullet Racing cams - talk to their experts about exactly what roller cam they'd recommend (along with how much carb). Also ask them what ratio rockers and spring package for the given cam. These guys really do great work, their cams run really well -- street, Bonneville, blown, alky - you name it. You'll like their service and be very happy with the results. Also, to have the old school look, better get yourself a nice Vertex Mag! LOL
  23. GlassThamesDoug
    GlassThamesDoug
    Early Corvette Pistons. 11.5:1 CR Good Dome... Short Reach Spark Plugs Indexed required or you will close the electrodes.
  24. 77amc
    77amc
    Aron, Did you ever finish this 283?
    I'd like to hear what and how...
    E
  25. Hdonlybob
    Hdonlybob
    Deuces likes this.
  26. anothercarguy
    anothercarguy
    Looks like the original poster has not been to this site since April 2017.
  27. Deuces
    Deuces
  28. ct1932ford
    ct1932ford
    Probably sold it and bought a new Camry.:eek:
