Technical 283 identification
Discussion in 'Traditional Hot Rods' started by OWes21, Jan 19, 2024.
  1. Mr48chev
    68 C 10 327 if it is YV. Y pretty well says it is a 66/68 truck 327. Screenshot (768).png
    Black Panther likes this.
  2. OWes21
    OWes21
    I wouldn't know lol
  3. squirrel
    I guess he doesn't want to sell it?
  4. OWes21
    OWes21
    Interesting
  5. Moriarity
    Moriarity
    SUPER MODERATOR
  6. lumpy 63
    lumpy 63
    I think most every small journal 327 I've had was a 657 block
  7. squirrel
    the only one I've ever had was an 817.
  8. lumpy 63
    lumpy 63
    Whats in the Vette?
  9. OWes21
    OWes21
    Just an older guy. I should have made sure to get my own pictures when looking at it. I left and realized they weren't very clear
  10. saltflats
    saltflats
    from Missouri
    I would say by the shape of the flange of the crankshaft it's a 327.
    -Brent-, mad mikey, lumpy 63 and 2 others like this.
  11. OWes21
    OWes21
    Could what looks like a W be an M that was stamped upside down?
    Blade58 likes this.
  12. Dyslexic ***embly guy at gm
    Probably me in another life
    SS327, mad mikey and Truckdoctor Andy like this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    YW is the suffix for a 60 series truck. 1967 327
  14. I like the big trucks. Good cranks.
    Some had oddball casting head numbers. Old round track guys around here used em.
  15. saltflats
    saltflats
    from Missouri
    I worked on one of the early 60s cabover trucks that had a 327 with a crank driven radiator fan. Had broken a crankshaft. I will never forget working at that shop, I have life enlightening experience from that place. Lucky to make it out not maimed or dead. :eek:
    mad mikey, -Brent- and SS327 like this.
  16. squirrel
    not many guys have the truck book
  17. Rex_A_Lott
    Rex_A_Lott
    Unless its stupid money, its worth the asking price, those arent just laying around anymore. Good Luck.
    mad mikey likes this.
  18. DDDenny
    Maybe
    The Magnaflux test is going to verify that!
  19. OWes21
    OWes21
    Thank you everyone!
    bchctybob likes this.
  20. OWes21
    OWes21
    The motor was cheap so I grabbed it. Don't really know much but starting to pull it apart to get more info. I cleaned and got some more pictures.
    -Brent-, Truckdoctor Andy and swade41 like this.
  21. squirrel
    the stamp looks like...the engine was "decked", and then restamped with the original numbers, but not with the original style stamps. That's why the "W" looks so weird, it's an upside down M. But the original stamp is clearly visible.
    The diagonal machining marks are the evidence that it was decked, originally it had been broached, the machine marks are lines that go from front to back.
    That head is from 1965.
  22. OWes21
    OWes21
    I noticed the faint stamp and I thought that may be the case. The numbers do appear to match up.
    It's truly amazing the details you can remember, thank you!
    -Brent- likes this.
  23. OWes21
    OWes21
    What would cause someone to machine down the block "decking"?
  24. squirrel
    If the deck surface is damaged by corrosion or something, or if they want to "square" the block to the crankshaft center line.
  25. 31Apickup
    31Apickup
    It’s a 4” bore block. In 67 the 327 that used this block were small journal, GM also used this same block for the 350 in the Camaro machined for the large journal 350 crank. I have the same block sitting in my coupe ( mines a 327 small journal)
    -Brent- likes this.
