Hot Rods 283 in a fire,any good?
Discussion in 'The Hokey Ass Message Board' started by scoop, Nov 6, 2024.
  1. BJR
    BJR
    Back in the late 60's I worked at a bodyshop that bought cars that had engine fires to fix up and sell. We would make sure they were not locked up, put new carbs, hoses, vacuum lines, and wiring harnesses on them. Never had one that didn't run after we did that. But these were cars that just had engine fires. Not cars that burned in a garage or other building, which get much hotter.
    Sharpone likes this.
  2. sunbeam
    sunbeam
    If there is oil in it check it oil get funky at around 400 degrees
  3. scoop
    scoop
    Got the engine home, heads look good but the number 2 cylinder has a bad gouge in it like a ring busted. So I'm s****ping the block and keeping the heads for future projects.
    Sharpone and clem like this.
  4. Wish you was closer.
    I ain’t skeered of a scratched cyl
    Budget36, Sharpone and Johnny Gee like this.
  5. Sharpone
    Sharpone
    You can sleeve the cylinder
    Dan
    Budget36 and Unkl Ian like this.
  6. Unkl Ian
    Unkl Ian
    Depending on how deep the score is, it can be bored oversize.
    Sharpone and Budget36 like this.
  7. SS327
    SS327
    Keep the crank and rods for that 302 build!
  8. Budget36
    Budget36
    It’s a 283, right? Couldn’t many of them go .120/.125 over?
    SS327 and Sharpone like this.
  9. Unkl Ian
    Unkl Ian
    Yes, was done at one point.
    IIRC, depends on the year of the block.
    Earlier ones were thicker.
  10. HRBOB34
    HRBOB34
    I bought a burnt corvette once. was using for parts, I sold the transmission,to a friend,
    he brought it back, because close inspection you could see everything that was bolted together was warped? The fire got that hot! JUNK! so, look close!
  11. scoop
    scoop
    .040 pistons, the gouge is so deep that wouldn't clean up.
  12. scoop
    scoop
    I would imagine the fibergl*** probably burnt hotter.
  13. Jack E/NJ
    Jack E/NJ
    from NJ
    > >cylinder has a bad gouge> >gouge is so deep that wouldn't clean up. > >am> > I ain’t skeered of a scratched cyl > >
    Post a picture of gouge if possible.
  14. It’s just extra oiling
